Ok my turn for a problem (VB)
Currently Active Users: 1778
Discussions: 200,990, Posts: 2,379,885, Members: 246,359
Old March 14th, 2002, 08:05 PM   Digg it!   #1 (permalink)
Not Really a Member
Red face
Ok I've been bashing my head into this monitor for a few days on this one
This is going to be confusing as hell lol
Ok what I'm doing is creating a custom outlook 2000 form that populates some of the data on the form from an XML document in a public folder.. that part is not the problem. I am now "simply" having a problem retrieving some of the data from the XML file.
Ok here is a summary of some of the code and the XML I'm using....
Code:
Function GetAgencyInfo()      'Routine to read the time card info into the XML Doc object
  Dim strXML
  GetAgencyInfo = False       'Set the return value to false, indicating the info was not read
  'Get the XML body of the time card information item.  Notify the user if can't find it.
  'Load the XML body into strXML
  strXML = ""
  strXML = Application.GetNameSpace("MAPI").Folders("Public Folders").Folders("All Public Folders").Folders("ParentFolderName").Folders("SubFolderName").Folders("EvenMoreSubFolderName").Folders("AnotherSubFolder").Items("Message Title").Body
  If strXML = "" Then
    MsgBox "Can't find " & "Message Title" & "--the item that holds the time card data"
    Exit Function
  End If
  Set g_xmlDoc = CreateObject("Microsoft.XMLDOM")
  g_xmlDoc.async = "false"
  g_xmlDoc.loadXML (strXML)
  GetAgencyInfo = True        'Set the return value to true, indicating that the XML is in g_xmlDoc
End Function
Sub PopulateAgencies()       'Routine to populate the customer list with customers
                'that have tasks to which the user can charge
  Dim objAgencyNodes, objAgencyNode
  g_objControls("cmbOrganization").Clear      'Clear the Customer List
  Set objAgencyNodes = g_xmlDoc.getElementsByTagName("TLAgency")
  For Each objAgencyNode In objAgencyNodes
    g_objControls("cmbOrganization").AddItem (objAgencyNode.getElementsByTagName("Name").Item(0).Text)
  Next
  g_blnFormIsLoading = False ' Now we want to allow the user events for UserDept and UserOrg to be fired
  Set g_objSelCustNode = GetAgencyNode(Item.UserProperties("UserOrg"))
  If g_objSelCustNode Is Nothing Then
    MsgBox "Ah g_objSelCustNode = nothing"
  Else
    MsgBox "g_objSelCustNode = something, good!"
  End If
  Set objAgencyNodes = Nothing
  Set objAgencyNode = Nothing
End Sub
Sub PopulateOffices()
  Dim objOffices
  Dim objOffice
  Set objOffices = Nothing
  Set objOffice = Nothing
  g_objControls("cmbOfficeSymbol").Clear
  g_objControls("cmbOfficeSymbol") = ""
  Set objOffices = g_objSelCustNode.selectNodes("OfficeSymbol")
  If objOffices Is Nothing Then
    MsgBox "No Data For ObjOffices"
    Exit Sub
  End If
  MsgBox "objOffices = " & objOffices.Length
  'Populate the task list with only those tasks to which the user can charge
  For Each objOffice In objOffices            'For each Office
    g_objControls("cmbOfficeSymbol").AddItem (objOffice.getElementsByTagName("Name").Item(0).Text)
    MsgBox "For each objoffice in objoffices next box should be a task name"
    MsgBox objOffice.getElementsByTagName("Name").Item(0).Text & " Task Name"
  Next
End Sub
Function GetAgencyNode(strAgencyName)
  Dim objAgencyNodes
  Dim objAgency
'  ''' On Error Resume Next
  Set GetAgencyNode = Nothing         'Initialize the customer node to nothing
'''  Set objAgencyNodes = g_xmlDoc.selectSingleNode("TLAgency")
  For Each objAgency In objAgencyNodes
    If objAgency.getElementsByTagName("Name").Item(0).Text = strAgencyName Then
      MsgBox "GetAgencyNode=" & objAgency.getElementsByTagName("Name").Item(0).Text
      Set GetAgencyNode = objAgency         'Set the return value
      Exit For
    End If
  Next
  Set objAgency = Nothing
End Function
anything starting with g_ is global so you won't see it declared here
now for the XML
Code:
<?xml version="1.0" ?>
<UCRAgencyInfo>
  <TLAgencies>
    <TLAgency>
      <Name>Group 1</Name>
      <Description>Full Description of Group 1</Description>
      <OfficeSymbol>
        <Name>OS 1</Name>
        <Name>OS 2</Name>
        <Name>OS 3</Name>
      </OfficeSymbol>
    </TLAgency>
    <TLAgency>
      <Name>Group 2</Name>
      <Description>Full Description of Group 2</Description>
      <OfficeSymbol>
        <Name>Ummmm stuff</Name>
        <Name>2nd bit of stuff</Name>
        <Name>3rd bit of stuff</Name>
      </OfficeSymbol>
    </TLAgency>
  </TLAgencies>
</UCRAgencyInfo>
The problem...
I can get it to put Group 1, and Group 2 into a drop down box no problem.. now what is supposed to happen is it will populate a 2nd drop down box with the office symbols pertaining to THAT group.
For instance if I select Group 1 then OS 1, OS 2, OS 3 should show up in teh 2nd drop down box...
however, only OS 1 shows up
I can't for the life of me get the rest of that freakin' data LOL
I don't like the structure of it much, but I basically got a lot of this from another prog one of the other guys wrong, and applied to my case... however I haven't done a very good job of it lol
Any ideas?
vass0922 is online now   Reply With Quote
Old March 14th, 2002, 08:34 PM     #2 (permalink)
Ordained Mommy
NeoStarO1's Avatar
Whoa vass and I thought I was gonna see a "lifes" problem!
Wish I can help out with that one! Sorry
Can't wait to see the results of the answer tho.
NeoStar
NeoStarO1 is offline   Reply With Quote
Old March 14th, 2002, 09:07 PM     #3 (permalink)
Pshawn5's Avatar
Send a message via ICQ to Pshawn5 Send a message via AIM to Pshawn5 Send a message via MSN to Pshawn5 Send a message via Yahoo to Pshawn5
*bump for vass* since he was soo kind to write that thing up for me,even though i think it wont work
Pshawn5 is offline   Reply With Quote
Old March 14th, 2002, 09:21 PM     #4 (permalink)
Banned
qball's Avatar
let's see, you want the choice of a dropdown to filter (or populate) another dropdown...
So when I choose an agency, then office dropdown only shows offices for that agency, right???
Piece o' cake in PB, oops this is VB.
My guess is your parsing your XML improperly, where as you need to store data and display dependent upon choice...
qball is offline   Reply With Quote
Old March 14th, 2002, 09:31 PM     #5 (permalink)
Not Really a Member
Correct, I simply don't know which objects/methods fit into the puzzle correctly
I'm not real familiar with the API unfortunately... I've figured out a lot...
Ok my take on things...
One of a few things...
Returns 1, instead of 3 which it should be...
GetAgencyNode()
Using the wrong method to get the node...
or a better way to do this...
g_objControls("cmbOfficeSymbol").AddItem (objOffice.getElementsByTagName("Name").Item(0).Te xt)
Old March 14th, 2002, 11:07 PM     #6 (permalink)
I didn't read the whole code (it's late & i've got a headache), but one line says:
Is that right? I mean the use of the "" with a boolean type? Shouldn't it just be:
g_xmlDoc.async = False
Mr. NoOne is offline   Reply With Quote
Old March 14th, 2002, 11:09 PM     #7 (permalink)
Not Really a Member
yeah typically... like I said I didn't write that part.. Don't think it'll make that much of a difference but I will give it a shot
didn't really pay attention to it LOL
Old March 14th, 2002, 11:12 PM     #8 (permalink)
Not Really a Member
I changed it, same result... *sigh*
Don't make me go to another forum
lol
posted on another forum... see what happens..
http://www.vbxml.com/messageboards/m...=vbxmlprog3788
(site sucks in opera!! arghhh)
Old March 26th, 2002, 12:38 AM     #9 (permalink)
WOW!!! Interesting
try this:
Set one_objOffices = g_objSelCustNode.selectNodes("OfficeSymbol")
Set objOffices = one_objOffices .getElementsByTagName("Name")
if this looks something stupid, just ignore me... LOL
this is my first time looking at VB
i usually prog in C
kakyoin is offline   Reply With Quote
Old March 27th, 2002, 04:27 PM     #10 (permalink)
ph34r t3h g04t
Whir's Avatar
Vass - You get an answer to this yet??? A colleague of mine suggested reading the XML file as a database using ADO. This way, you can use standard filter methods with the controls. I am not 100% clear on exactly how he meant to use it, but it equates to setting the XML files as the database and then the tags as recordsets. You can declare deeper tags as they're own recordsets and declare the upper ones as primary keys through code and have the filters sort that way? Follow? I understand how he got his to work sort of, but explaining it is like trying to teach myself how to speak. :P
-Whir
Is It Just Me? (3075)
Health Care Rationing (12)
Delete an OS (17)
Nvidia GTX 260 problem (10)
Internet Lost (5)
Foxconn Blackops x48 MoBo (2)
Q9650 vs. Q9550 (0)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
Can't open Word (12)
