help with META tags
Currently Active Users: 1681
Discussions: 200,933, Posts: 2,379,189, Members: 246,298
Old December 4th, 2005, 11:22 AM   Digg it!   #1 (permalink)
AFMAN10's Avatar
Question
help with META tags
can anyone explain how to use meta tags (for search engins) to me?
AFMAN10 is offline   Reply With Quote
Old December 4th, 2005, 11:45 AM     #2 (permalink)
Steeler Fan
jman01pa's Avatar
http://searchenginewatch.com/webmast...le.php/2167931
There is much information on the net. You want search engines to find you, use them to help you too.
Google
Most search engines can tell you how to get listed on there site. As stated in the top link "Meta tags are not a magic solution"
Here is Googles info
http://www.google.com/webmasters/
jman01pa is offline   Reply With Quote
Old December 4th, 2005, 12:00 PM     #3 (permalink)
AFMAN10's Avatar
wow... thats a lot of info.... thanks.
Custom Tags in CS:S Fofo General Gaming Discussion 12 November 13th, 2009 02:12 PM
RFID tags and you diode IMO Community 0 December 2nd, 2004 09:00 PM
Meta Tags Question Super Nick Webmastering and Programming 4 July 16th, 2004 03:26 AM
MP3 TAGS Blazer06 Multimedia and Audio 5 March 27th, 2004 09:04 AM
Head Tags: META & KEYWORDS, Difference? ClubMed Webmastering and Programming 7 July 15th, 2003 08:58 AM
Is It Just Me? (2882)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
Wireless Televisions. (4)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
