SQL help
Currently Active Users: 2355
Discussions: 200,940, Posts: 2,379,262, Members: 246,302
Old December 20th, 2005, 07:22 PM   Digg it!   #1 (permalink)
AFMAN10's Avatar
Unhappy
SQL help
I am switching hosts and have 2 databases I am trying to transfer. I get the following error:
Code:
st69:/usr/local/mysql/bin#./mysql filkovsk_gallery < /home/filkovsk/public_html/cgi-bin/'SQL backups'/filkoveforum.sqlERROR 1064 at line 19: You have an error in your SQL syntax.  Check the manual that corresponds to your MySQL server version for the right syntax to use near 'ENGINE=MyISAM DEFAULT CHARSET=latin1 AUTO_INCREMENT=63' at line
I know it has to do with the fact that my old host and new host use different versions of myphpadmin.
Please help.
AFMAN10 is offline   Reply With Quote
Old December 22nd, 2005, 10:18 AM     #2 (permalink)
Send a message via ICQ to exally
hmm don't know much about this side of SQL but incompatible versions?
exally is offline   Reply With Quote
SQL question... Tekk Webmastering and Programming 4 October 5th, 2004 01:25 AM
SQL Help!!!!! Craisx Webmastering and Programming 9 November 22nd, 2002 03:59 AM
I need help with My SQL please e980238 Webmastering and Programming 6 April 14th, 2002 06:09 AM
Is It Just Me? (2910)
Wireless Televisions. (8)
Obama the Muslim (14)
Regular Build (5)
Open With ..... Win7 (0)
Regular Build (5)
java code for fibonacci (1)
screen resolution vs monitor size (0)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
