prime number problem
Currently Active Users: 1492
Discussions: 200,987, Posts: 2,379,855, Members: 246,352
Old March 25th, 2007, 10:51 PM   Digg it!   #1 (permalink)
//libraries
#include <iostream>
#include <cmath>
#include <fstream>
#include <iomanip>
using namespace std;
//function prototypes
void printmessage (ofstream &, int);
void printprimes (ofstream &, int);
bool isprime (int);
//enter the main
int main ()
ifstream in;
ofstream out;
//open data file
in.open("in.txt");
//if not open give error message
if (!in)
cout << "Did not open in.txt" <<endl;
return 1;
//open output file
out.open("out.txt");
//if not give error message
if (!out)
cout << "Did not open out.txt" << endl;
return 1;
// local variables
int input, n;
//priming read
in >> input;
//start of the loop
while (in)
//function
printmessage (out,input);
if (isprime (input))
// EOF
in >> input;
cout << "THE END." << endl;
//close the file
in.close();
out.close();
system ("pause");
return 0;
//Output
void printmessage (ofstream & out, int input)
out <<endl;
out << "The number is " << input;
out <<". The prime numbers less than or equal to " << input << " are: " << endl;
void printprimes (ofstream & out, int n)
cout << n << " ";
out << n <<" ";
bool isprime (int n)
int realnum, divisor, count;
ofstream out;
for (realnum=2; realnum <= n; realnum++)
{count = 0;
for (divisor=2; divisor < sqrt(n); divisor++)
{if (realnum % divisor == 0 && realnum != divisor)
{count = 1;
if (count == 0)
printprimes (out, realnum);
now my problem is it wont output to file, but it will to screen. It is probably something really simple, but i have been staring at it for 3 days and can't figure it out. Any help will be appreciated. thanks, i'm a new user
firecookie2k is offline   Reply With Quote
Old March 26th, 2007, 01:50 PM     #2 (permalink)
Smile
wont print prime number to file, but will to screen
Maybe you guys can help me with this C++ program. I wrote all of the code and just need a little help to finish. It is due by Wednesday. I can get the cod ebelow to print to screen using cout, but cannot get to print to a notepad file called out.txt. It opens the file and also prints out the printmessage to file, but does not print out printprimes. Any help will be greatly appreciated. Sorry this is the second time i posted, but I guess the first one wasn't detail enough.
//libraries
#include <iostream>
#include <cmath>
#include <fstream>
#include <iomanip>
bool isprime (int);
//enter the main
int main ()
ifstream in;
ofstream out;
//open data file
in.open("in.txt");
if (!in)
return 1;
//open output file
if (!out)
return 1;
// local variables
int input, n;
//priming read
in >> input;
//start of the loop
while (in)
//function
// EOF
in >> input;
//close the file
in.close();
out.close();
system ("pause");
return 0;
//Output
out <<endl;
cout << n << " ";
out << n <<" ";
ofstream out;
{count = 0;
{count = 1;
if (count == 0)
Old March 26th, 2007, 02:06 PM     #3 (permalink)
Caveat Emptor
Rootstonian's Avatar
I'm surprised you're not getting an error on isprime; it should be expecting a RETURN value and I don't see one.
You're aslo declaring 2 ofstream out. The one in isprime is bogus.
Maybe you need to return a value from isprime and "do something" based on that
Old March 26th, 2007, 07:16 PM     #4 (permalink)
Smile
still not working
when i return a value from the bool function the only output is
4436984 three times. i have no idea where that value is coming from. if i put printprimes as a function after if (isprime), it just prints out all of the numbers up to the input.
Old March 26th, 2007, 07:22 PM     #5 (permalink)
sulusulu's Avatar
Have you tried going through your program with a calculator and pencil? I have found that this procedure usually points out any errors.
Accept that some days you're the pigeon, and some days you're the statue. -- Scott Adams
sulusulu is offline   Reply With Quote
Old March 26th, 2007, 07:41 PM     #6 (permalink)
Caveat Emptor
According to your function prototype, isprime is to return a BOOL; 0 or 1 or TRUE or FALSE. I see no return 0; return 1; return TRUE or return FALSE in that function.
I'll psuedocode this for you...you're close, but I'm not going to "give" it to you
Open Files
While not EOF Input file
Read Input File
Is this number Prime?
Yes...print to screen....print to file
No...do nothing
back to start of while loop
Out of while loop
Close Files
End Program
I'm not trying to be an a$$, but it really is this easy. Start a new source file and cut and paste from your original. I've done that a thousand times when I get stuck with a program; sometimes you spend too much time trying to fix what you first wrote. Doing it over from scratch gives you a fresh start (and 9 times out of 10 a new and correct view of the program).
prime voltages italiamodena575 Technical Support 2 December 20th, 2004 01:57 AM
Counter Striker Key number! Problem leosmdp General Gaming Discussion 5 August 2nd, 2004 11:58 AM
Prime 95 found a problem... MitaDC General Tech Discussion 8 June 1st, 2004 10:58 AM
GIMPS finds the largest prime number Virus Distributed Computing 0 December 5th, 2001 11:33 PM
Is It Just Me? (3063)
Health Care Rationing (11)
Delete an OS (17)
Nvidia GTX 260 problem (9)
Point and Shoot Camera Suggestions. (7)
Internet Lost (5)
How to convert Mod/Tod video to AVI/M.. (0)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
Can't open Word (12)
