C++ Programming Help
Currently Active Users: 1826
Discussions: 200,933, Posts: 2,379,200, Members: 246,298
Old April 30th, 2007, 12:06 AM   Digg it!   #1 (permalink)
I'm supposed to have editted a class file for class and use it in a program. I editted the class with no trouble, and I put it in the include folder (I'm using Microsoft Visual Studio 6.0), but the program thats using the class can't find it when I include it in the program I'm supposed to be working with it in.
The specification file for the class header is
#include <mylist.cpp>
The implementation file for the class header is
#include <mylist.h>
#include <iostream>
using namespace std;
Program using the .h file is
#include <iostream.h>
#include <mylist.h>
I've tried using quotations around the includes for the "mylist.h" and the "mylist.cpp" but still no go. Any help would be appreciated.
umax is offline   Reply With Quote
Old April 30th, 2007, 01:20 AM     #2 (permalink)
Vyx
Vyx's Avatar
Send a message via AIM to Vyx Send a message via MSN to Vyx Send a message via Skype™ to Vyx
In VS 2005, the way I do it is to put the header file in your project directory ie. C:\Documents and Settings\Brandon\My Documents\Visual Studio 2005\Projects\COSC\COSC and then for the include: do #include "time.h"
I'm not sure in v6, althought it should be the same.
Also, I'm not sure if this is how you have it or not but from what you have:
It looks like you header file is named as a cpp file. it needs the .h file extension.
Hope this helps.
Gi | Yuu | Jin | Rei | Makoto | Meiyo | Chuugi
Vyx is offline   Reply With Quote
Old April 30th, 2007, 02:30 AM     #3 (permalink)
Yes, it did somewhat lol, but now I have an error
c:\program files\microsoft visual studio\myprojects\program4\mylist.h(10) : fatal error C1076: compiler limit : internal heap limit reached; use /Zm to specify a higher limit
As well as a warning
c:\program files\microsoft visual studio\myprojects\program4\mylist.h(10) : warning C4182: #include nesting level is 363 deep; possible infinite recursion
So anymore help would be appreciated :P
Old April 30th, 2007, 02:49 PM     #4 (permalink)
Send a message via ICQ to exally
make sure the .h file is in the same folder as the project and then include the .h
exally is offline   Reply With Quote
c++ programming one2adore30 Webmastering and Programming 17 August 31st, 2005 08:29 PM
Help with programming please andy1984 Webmastering and Programming 55 August 12th, 2005 11:07 AM
C++ programming HELP! TechKnickle Webmastering and Programming 3 September 19th, 2004 02:49 AM
Programming quantumlight Webmastering and Programming 22 September 10th, 2004 07:38 PM
Need help with C programming Lemon[H]ead Webmastering and Programming 9 July 8th, 2002 07:57 PM
Is It Just Me? (2889)
Wireless Televisions. (6)
Obama the Muslim (14)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
