C++ array loop w/ nested if statement problem
Currently Active Users: 2138
Discussions: 200,950, Posts: 2,379,422, Members: 246,311
Old February 28th, 2008, 01:40 PM   Digg it!   #1 (permalink)
Ramen's Avatar
Angry
Hey everyone. I've been trying to get this work for for a day now and can't figure out why it won't do what I want it to. Basically, I had to write an array that will input grades and output a list of grades or average the grades. Sounds easy huh? Well, I got that part done.. right here:
Code:
#include <iostream>
using namespace std;
void main()
	int Counter=1;
	int Assignment[7]= {0, 0, 0, 0, 0, 0, 0};
	int Selection, Lab, Count;
	float GPA;
	float Divisor = 7.0;
	int LabGrade;
	cout << "Please select for pay type from the following choices:\n";
	cout << "    1 - Input Letter Grade Data\n";
	cout << "    2 - Lab Average\n";
	cout << "    3 - Print Lab Grades to Screen\n";
	cout << "    0 - Exit\n";
	cin >> Selection;
	while (Selection != 0)
		switch (Selection)
		case (1):
			cout << "Enter lab number (1-7): \n";
			cin >> Lab;
			cout << "Enter current grade for lab: \n";
			cin >> LabGrade;
			Assignment[Lab-1] = LabGrade;
			cout << "Current lab " << Lab << ", is now " << LabGrade << ".\n\n";
			break;
		case (2):
			GPA = 0.0;
			for (Count=0; Count <=6; Count++)
				GPA = GPA + Assignment[Count];
			cout << "Current lab average is " << GPA / Divisor << ".\n\n";
			break;
		case (3):
			Count = 0;
			while (Count <= 6)
				cout << "Lab " << Count+1 << " grade is " << Assignment[Count] << ".\n";
				Count++;
			break;
		default:
			cout << "Enter correct menu selection.\n";
	cin >> Selection;
Well, instead of using numbers for the grades the user is supposed to be able to input letters (A, B, C, D, & F). Then save the letters they input as the score (A = 4, B = 3, C = 2, D = 1, & F = 0). Here's the code I wrote trying to make it work like I want it to, but it's not..
Code:
#include <iostream>
void main()
	int Counter=0;
	char LabGrade, A, B, C, D, F;
	float GPA;
	cin >> Selection;
		switch (Selection)
		case (1):
			while (Counter < 7)
				Counter = Counter + 1;
				cin >> Lab;
				cin >> LabGrade;
				if (LabGrade = 'A')
					A = 4;
				else
					if (LabGrade = 'B')
						B = 3;
					else
						if (LabGrade = 'C')
							C = 2;
						else
							if (LabGrade = 'D')
								D = 1;
							else
								if (LabGrade = 'F')
									F = 0;
			break;
		case (2):
			GPA = 0.0;
			break;
		case (3):
			Count = 0;
			while (Count <= 6)
				Count++;
			break;
		default:
	cin >> Selection;
Yeah, meow..
Ramen is offline   Reply With Quote
Old February 28th, 2008, 10:48 PM     #2 (permalink)
Super F@D Folder
i'm assuming your a student. Take my advice, properly indenting your code so that it's readable is KEY. It's probably the MOST important thing. It's what i stress most for those i'm teaching. If it's not readable i send it right back to them to redo it. I've reformatted the code so that it's much easier to read and it leaves the bug in your code quite obvious. I left a comment next to the bug as well describing it. Up to you to fix it though. Feel free to submit it for further review if you want advice as to how it could be done better... Best way to learn to code is to see how something you've written would have been done by someone with more experience! :-D I'm having trouble with that one now..i don't wanna admit i'm not the best and go look around! hehehe. Good luck on your assignment! email me if you want more help - u_kcormier at umassd dot edu
Code:
#include <iostream>
void main()
	int Counter=0;
	float GPA;
	cin >> Selection;
		switch (Selection)
			case (1):	while (Counter < 7)
					cin >> Lab;
					cin >> LabGrade;
					if (LabGrade = 'A') A = 4;
					else if (LabGrade = 'B') B = 3;
					else if (LabGrade = 'C') C = 2;
					else if (LabGrade = 'D') D = 1;
					elseif (LabGrade = 'F') F = 0;
					//here's your bug?  the if else structure above does nothing!  LabGrade is just a character, being put into an array of ints....whoops
				break;
			case (2):	GPA = 0.0;
				break;
			case (3):	Count = 0;
				while (Count <= 6)
					Count++;
				break;
			default:
		cin >> Selection;
Old February 28th, 2008, 11:18 PM     #3 (permalink)
lost-and-found's Avatar
Send a message via AIM to lost-and-found
Also, another problem I see in the code is in your if statements
you have:
Code:
if(Labgrade='A')
which should be
Code:
if(Labgrade=='A')
lost-and-found is offline   Reply With Quote
Old February 29th, 2008, 12:42 AM     #4 (permalink)
Caveat Emptor
Rootstonian's Avatar
It's late and I'm tired, but this is a pretty basic CS 101 assignment.
Yeah, keep your code cleaner indentation wise. Break it down into easy steps:
1. Get Data
2. Store Data
3. Calc Data
4. Print Data
Define your array like:
int MaxArraySize = 7;
char Grade_Array[MaxArraySize];
int num_grades_entered; // you'll have to count these
Then you can calc average with for loop...
int sum = 0;
float average;
for (int i=0; i < num_grades_entered; ++i) {
if(Grade_Array[i] == 'A')
sum += 4;
if(Grade_Array[i] =='B')
sum += 3;
if(Grade_Array[i] == 'C')
sum += 2;
if(Grade_Array[i] == 'D')
sum += 1;
if(Grade_Array[i] =='F')
sum += 0;
average = sum/num_grades_entered;
Old February 29th, 2008, 12:52 PM     #5 (permalink)
Ramen's Avatar
Talking
Thanks everyone for their input. I finally fixed my problem with all of your help.I thught my indenting was pretty good, but I guess not.. hehe.. I'll work out it though.
When I was working through it last night before you all posted I did notice that having my array as int was screwing me up because like sr71000 pointed out with the comment is trying to use LabGrade char in an int array. So I solved that, fixed my comparisons using == instead of just = like lost suggested. (That's another habit I need to break cause I've done that in the past with other assignments and it's messed me up) Finally, with Rootstonian's help with the averaging it all worked out. I think I just needed to take a break, get some good advise, and try some options that was given. No wonder I love TechIMO community so much.. hehe.
Bootup Loop Problem ** $ Prize Sandizzle Technical Support 5 September 12th, 2007 10:10 AM
x1600pro constant loop problem dru_down Graphics Cards and Displays 0 August 22nd, 2006 02:16 PM
Excel nested IFs or Index rmanja Applications and Operating Systems 0 November 18th, 2005 07:56 PM
Java if statement problem... Blazer06 Webmastering and Programming 3 February 23rd, 2005 11:20 AM
Load an array w/ a do/while loop Martoch Webmastering and Programming 6 October 14th, 2002 09:02 PM
Making Health Care Worse (176)
Is It Just Me? (2940)
The disrespect of Obama by Russian .. (26)
Regular Build (6)
Print spooler problem (15)
Happy Thanksgiving: At discount from .. (0)
Point and Shoot Camera Suggestions. (3)
How to convert MP3's (4)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
