Help on running a specific SQL statement
Currently Active Users: 2470
Discussions: 200,959, Posts: 2,379,551, Members: 246,329
Old June 18th, 2008, 05:23 PM   Digg it!   #1 (permalink)
Tekk's Avatar
So Im trying to figure out how to compare two tables and get a listing of records that do NOT appear in the other.
Table 1 contains information that Im comparing to Table 2 and I want any records in T1 that do NOT appear in T2 to show in the results. I have some examples below:
Code:
TABLE 1
T-Code		Auth_Object		Attribute	Attribute Value
ME21		M_BEST_BSA		ACTVT		01
ME21		M_BEST_BSA		ACTVT		02
ME21		M_BEST_BSA		BSART		XX
ME21		M_BEST_EKG		ACTVT		01
ME21		M_BEST_EKG		EKGRP		XX
TABLE 2
So when running the proposed query against the above data, I would want the following records to be included in the results:
Code:
Any help in creating a query that will assist me in running this on a multitude of records in the tables? Thanks in advance.
YAH! I knew you'd be jealous
Tekk is offline   Reply With Quote
Old June 18th, 2008, 09:21 PM     #2 (permalink)
Super F@D Folder
anything like this?
[thelist] MySQL comparing two tables
Old June 18th, 2008, 09:48 PM     #3 (permalink)
Not Really a Member
Originally Posted by sr71000 View Post
I would go with the join method in mentioned in this article
select *
from table 1 t1
LEFT OUTER join table2 t2
on t1.[t-code] = t2.[t-code]
on t1.[auth_object] = t2.[auth_object]
on t1.[Attribute] = t2.[Attribute]
on t1.[Attribute Value] = t2.[Attribute Value]
WHERE [t-code] IS NULL
OR [auth_object] IS NULL
OR Attribute IS NULL
OR [Attribute value] IS NULL
btw, this will give you half the results you want, you can figure out the rest
FYI I REALLY dont like the structure of this table
1. Spaces in column names
2. hyphens in column names
3. No standard in seperating words (I typically change case of first letter in each word AttributeValue). If you dont like changed case, then keep with underscore, with hyphens you have to use brackets and they're just annoying
4. Attribute and Attribute value probably shouldn't be in the same table.
vass0922 is online now   Reply With Quote
Old June 19th, 2008, 10:05 AM     #4 (permalink)
Caveat Emptor
Rootstonian's Avatar
SELECT
A.T-CODE,
A.AUTH_OBJECT,
A.ATTRIBUTE,
A.ATTRIBUTE VALUE
FROM TABLE1 A
WHERE NOT EXISTS
(SELECT 'X'
FROM TABLE2 B
WHERE
A.T-CODE = B.T-CODE
AND A.AUTH_OBJECT = B.AUTH_OBJECT
AND A.ATTRIBUTE = B.ATTRIBUTE
AND A.ATTRIBUTE VALUE = B.ATTRIBUTE VALUE)
forming SQL Insert statement ShuckyD Webmastering and Programming 5 August 1st, 2007 08:49 AM
SQL statement help (pretty basic) ZeR0 Webmastering and Programming 2 February 23rd, 2006 01:38 PM
Running SQl server Scripts Sunayana Webmastering and Programming 2 October 25th, 2002 06:01 PM
Is It Just Me? (2975)
The disrespect of Obama by Russian .. (45)
Making Health Care Worse (181)
CPU fan stops spinning randomly (10)
Point and Shoot Camera Suggestions. (5)
Print spooler problem (16)
Nvidia GTX 260 problem (0)
Open With ..... Win7 (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
