i need help on my aol page with frames
Currently Active Users: 1459
Discussions: 200,927, Posts: 2,379,135, Members: 246,293
Old May 8th, 2002, 06:58 PM   Digg it!   #1 (permalink)
JacobM5727's Avatar
Send a message via ICQ to JacobM5727 Send a message via AIM to JacobM5727 Send a message via Yahoo to JacobM5727
Unhappy
help... aol page with frames
i have aol.. yeah, i know.. anyways
i want to redo my page, i finally got dreaweaver working, i have version 3.0
here are the files:
frameset
http://www.members.aol.com/jacobm5626/index2.html
top frame
http://www.members.aol.com/jacobm5626/frametop.html
left frame
http://www.members.aol.com/jacobm5626/frameleft.html
middle frame
http://www.members.aol.com/jacobm5626/framemid.html
all of them work, but not the frameset.. aol says this in their help
Frames: If your Web pages use frames, be sure to add ONLY the top page to AOL Hometown. There is no need to add each frame to a AOL Hometown community and doing so may cause your frames to display improperly.
what does that mean, i am easily confused with site stuff.. thanks
o, also the applet, and the banner, and the music..
are just there so i can more easily id a page
also, this is the first time i have gotton dreamweaver to work with aol, and so its the first time i have used it..
--Jacob--
JacobM5727 is offline   Reply With Quote
Old May 8th, 2002, 07:14 PM     #2 (permalink)
ChoaticWhisper's Avatar
Send a message via AIM to ChoaticWhisper
Well one the midframe.html should be framemid.html.
Maybe try removing the / infront of the html pages.
ChoaticWhisper is offline   Reply With Quote
Old May 8th, 2002, 07:14 PM     #3 (permalink)
ZENYO's Avatar
It's been a while since i did any html stuff but Try deleting the / from the frameleft.html, framtop.html and framemid.html. If they are kept in the same directory it shouldn't be needed.
Eat, drink and be merry...
ZENYO is offline   Reply With Quote
Old May 8th, 2002, 07:14 PM     #4 (permalink)
ZENYO's Avatar
You beat me Choatic!
Old May 8th, 2002, 07:17 PM     #5 (permalink)
JacobM5727's Avatar
what do you guys mean by deleting the /?
http://www.members.hometown.aol.com/...6frametop.html?
Old May 8th, 2002, 07:19 PM     #6 (permalink)
ZENYO's Avatar
instead of
<frame src="/frameleft.html"
try
<frame src="frameleft.html"
for all three frames
Old May 8th, 2002, 07:20 PM     #7 (permalink)
JacobM5727's Avatar
oo, ok..
edit:
i did that and it said i entered an invalid html tag
Old May 8th, 2002, 07:23 PM     #8 (permalink)
what are you using to create your page?
Old May 8th, 2002, 07:24 PM     #9 (permalink)
JacobM5727's Avatar
dreamweaver 3
Old May 8th, 2002, 07:25 PM     #10 (permalink)
ZENYO's Avatar
Are the top, left and main page in the same directory as the frame page? if so, try copying the text into notepad then make the changes. Don't forget to type in .html when you save it.
Is It Just Me? (2866)
Obama the Muslim (14)
Fire in DVD (2)
Safe International POS for CC,DC cash.. (0)
Regular Build (0)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
