Join TechIMO for Free!
Thread Tools
Currently Active Users: 2719
Discussions: 186,607, Posts: 2,227,057, Members: 230,242
Old September 15th, 2008, 01:23 AM   Digg it!   #1 (permalink)
Exclamation
Java script Help, Please throw me a life vest
I'm writing a mailing list using javascripts to validate that the first, last name and email address has some information in them, nothing specific just some info. The problem I'm having is when you dont fill in these three fields it suppose to redirect with a popup stating that one of three fields are'nt filled out and allow the user to attempt to fill out again. Bare with me I'm as green as it comes with this so I'm trying to learn as I can. Your help is appreciated, thanks and God Bless !!!!
<html>
<head>
<title>Kudler Customer Mailing List</title>
<!-- Nakia Cumming -->
<!-- WEB/406 Web Programming II-->
<!-- Professor Nancy Cosgrove -->
<script language="javascript">
function formCheck(formobj){
var fieldRequired = Array("FirstName", "LastName","eMail Address");
var fieldDescription = Array("First Name", "Last Name","eMail");
// Below is my error message
var alertMsg = "Please complete these fields:\n";
var l_Msg = alertMsg.length;
for (var i = 0; i < fieldRequired.length; i++){
var obj = formobj.elements[fieldRequired[i]];
if (obj){
switch(obj.type){
case "select-one":
if (obj.selectedIndex == -1 || obj.options[obj.selectedIndex].text == ""){
alertMsg += " - " + fieldDescription[i] + "\n";
break;
case "text":
case "textarea":
if (obj.value == "" || obj.value == null){
break;
default:
if (obj.type == undefined){
var blnchecked = false;
for (var j = 0; j < obj.length; j++){
if (obj[j].checked){
blnchecked = true;
if (!blnchecked){
if (alertMsg.length == l_Msg){
return true;
}else{
alert(alertMsg);
exit();
return false;
var count=0;
//This redirects where needed
function redirect()
if(!count)
location.href = 'Error.html';
else
location.href = 'Confirm.html';
</SCRIPT>
</head>
<body>
<body bgcolor="#000110"></body>
<center><table width="850" bgcolor="#c69b96"></center>
<tr>
<td>
<H1>Kudler Mailing list</H1><!-- Header -->
<H3>In order to recieve online coupons please fill out the form below.</H3>
<hr size="10" width="100%" noshade>
<form name="Customer" onsubmit="return validate(this);" form action="javascript:redirect();"><!-- Form -->
First Name:<br> <INPUT size=35 name=FirstName><br>
Last Name:<br> <INPUT size=35 name=LastName><br>
Address:<br> <INPUT size=35 name=Address><br>
City:<br> <INPUT size=35 name=City><br>
State: <br>
<select name="States">
<option value="" SELECTED></option><!-- Select Box -->
<option value="AL">Alabama</option>
<option value="AK">Alaska</option>
<option value="AZ">Arizona</option>
<option value="AR">Arkansas</option>
<option value="CA">California</option>
<option value="CO">Colorado</option>
<option value="CT">Connecticut</option>
<option value="DE">Delaware</option>
<option value="DC">District Of Columbia</option>
<option value="FL">Florida</option>
<option value="GA">Georgia</option>
<option value="HI">Hawaii</option>
<option value="ID">Idaho</option>
<option value="IL">Illinois</option>
<option value="IN">Indiana</option>
<option value="IA">Iowa</option>
<option value="KS">Kansas</option>
<option value="KY">Kentucky</option>
<option value="LA">Louisiana</option>
<option value="ME">Maine</option>
<option value="MD">Maryland</option>
<option value="MA">Massachusetts</option>
<option value="MI">Michigan</option>
<option value="MN">Minnesota</option>
<option value="MS">Mississippi</option>
<option value="MO">Missouri</option>
<option value="MT">Montana</option>
<option value="NE">Nebraska</option>
<option value="NV">Nevada</option>
<option value="NH">New Hampshire</option>
<option value="NJ">New Jersey</option>
<option value="NM">New Mexico</option>
<option value="NY">New York</option>
<option value="NC">North Carolina</option>
<option value="ND">North Dakota</option>
<option value="OH">Ohio</option>
<option value="OK">Oklahoma</option>
<option value="OR">Oregon</option>
<option value="PA">Pennsylvania</option>
<option value="RI">Rhode Island</option>
<option value="SC">South Carolina</option>
<option value="SD">South Dakota</option>
<option value="TN">Tennessee</option>
<option value="TX">Texas</option>
<option value="UT">Utah</option>
<option value="VT">Vermont</option>
<option value="VA">Virginia</option>
<option value="WA">Washington</option>
<option value="WV">West Virginia</option>
<option value="WI">Wisconsin</option>
<option value="WY">Wyoming</option>
</select><br>
Zip: <br><INPUT size=35 name=Zip><br>
Home Phone: <br><INPUT size=35 name="HomePhone"><br>
eMail Address: <br><INPUT size=35 name="eMail Address"><br>
<INPUT type=submit value="Submit Form"> <!-- Buttons -->
<INPUT type=reset value="Clear Fields" name=clear><br><br>
</td>
</tr>
</table>
</body>
</html>
nacummings is offline   Reply With Quote
FREE instant scan
Old September 17th, 2008, 05:25 AM     #2 (permalink)
Send a message via ICQ to exally
first of all, in the future please use code tags. secondly. Instead of having the message length as the determining factor use a simple bool, true or false, and set it if it doesn't work. also I believe you don't require exit();
In saying that where u have validate(this) in the form declaration, it might help if u changed it to formCheck(this).
exally is offline   Reply With Quote
Old September 22nd, 2008, 07:54 PM     #3 (permalink)
Exclamation
THANKS A BUNCH, from your advise I finally got it too work but I have to use the message length for this design. But now I wrote my cookies but I'm having trouble with these as well. Here is what I have so far, I'm definitely not good with cookies far from it, so please some simple language on this one....You fellows are the CODE WARRIORS, I call upon your help!!!!
if (obj){
switch(obj.type){
case "select-one":
break;
case "text":
case "textarea":
break;
default:
blnchecked = true;
if (!blnchecked){
return true;
}else{
alert(alertMsg);
return false;
var count=0;
function validate(frm)
//call function for validating, if ny field is empty
formCheck(frm);
//number of days for which the cookie is valid, here it is set to 99 days, may be changed by changin the value
var days=99;
var obj=frm.elements["eMail Address"];
var expires = new Date ();
expires.setTime(expires.getTime() + days * (24 * 60 * 60 * 1000));
if(obj.value==readCookie())
alert("Submission not allowed, the person has already filled form previously.The e-mail id is same!!");
count=0;
else
SetCookie(obj.value,expires);
//alert(readCookie());
count++;
function eraseCookie(name)
SetCookie( "", -1);
//function for reading cookie
function readCookie()
var ca = document.cookie.split(';');
var nameEQ = "TotalSubmissions" + "=";
for(var i=0; i < ca.length; i++)
var c = ca[i];
while (c.charAt(0)==' ')
c = c.substring(1, c.length);
//delete spaces
if (c.indexOf(nameEQ) == 0)
return c.substring(nameEQ.length, c.length);
return null;
//setting up cookie
function SetCookie(cookieData, expireDate)
document.cookie = "TotalSubmissions" + "=" + escape(cookieData) + "; expires=" + expireDate.toGMTString();
function GetCookie(name)
var arg = name + "=";
var alen = arg.length;
var clen = document.cookie.length;
var i = 0;
while (i < clen) {
var j = i + alen;
if (document.cookie.substring(i, j) == arg)
return GetCookieVal (j);
i = document.cookie.indexOf(" ", i) + 1;
if (i == 0) break;
return null;
function redirect()
if(!count)
else
</SCRIPT>
</head>
<body>
<tr>
<td>
<H1>Kudler Mailing list</H1><!-- Header #1 -->
<form name="Customer" onsubmit="return formCheck(this);" form action="javascript:redirect();"><!-- Form action -->
State: <br>
<option value="" SELECTED></option><!-- You select the state you reside in -->
</select><br>
<INPUT type=submit value="Submit Form"> <!-- The two buttons at bottom of page -->
</td>
</tr>
</table>
</body>
</html>
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Java script help Network67 Applications and Operating Systems 0 March 25th, 2005 04:48 AM
Java Script - Help! rcwabbits Webmastering and Programming 0 April 24th, 2003 11:44 PM
Java script and IE Bill in SD, CA Applications and Operating Systems 2 April 10th, 2003 03:39 PM
java script links Emc2 Webmastering and Programming 2 January 10th, 2003 07:20 PM
Daveleau, you need a life vest? desmocat IMO Community 1 July 2nd, 2002 11:13 PM
Is It Just Me? (530)
Misery Loves Company... (1849)
Why Does the MOON Grow Bigger as It.. (18)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (14)
1 internet. 1 house. 3 computer. ho.. (13)
SSD's, RAID, and External Backup (7)
32 or 64 bit vista (4)
Big problem with my PC (2)
system restore 'next' button wo.. (2)
Building my first PC and need s.. (1)
firewall (1)
C++ compiler suggestions (4)
Official World of Warcraft Thre.. (4529)
Programming question (2)
UPGRADING C/D DRIVE TO 250GB &a.. (14)
