Join TechIMO for Free!
Thread Tools
Currently Active Users: 2685
Discussions: 186,606, Posts: 2,227,046, Members: 230,241
Old September 21st, 2008, 01:09 PM   Digg it!   #1 (permalink)
Java: Problem displaying 0's in binary
Good day sirs.
I am creating a program to convert between decimal, binary and hexadecimal, and it works fine.
The problem is that I need binary outputs to display eight digits.
For example:
Decimal input of 5 yields "101" in binary but I need the output to show "00000101".
If it helps, I've been using Integer.toBinaryString(int), Integer.toHexString(int) to display output values.
Thanks in advance.
dchips13 is offline   Reply With Quote
FREE instant scan
Old September 21st, 2008, 07:15 PM     #2 (permalink)
Go back to sleep
Creatures's Avatar
Send a message via ICQ to Creatures
one way would be checking the length of the binary string and if the size is smaller than (in your example) 8 just add the remaining zeros so you get a string with 8 chars
i could give it a try...
Creatures
Knowledge Is Power
Creatures is offline   Reply With Quote
Old September 21st, 2008, 07:25 PM     #3 (permalink)
Go back to sleep
Creatures's Avatar
ah well that was a quick one ;p
Code:
	int x = 5;
	String str = Integer.toBinaryString(x); //int to bin string
	for(int q = 9;q >= str.length();q--) {
		str = "0" + str;           //adding 0's until string.length() = 8
	System.out.println(str);
you can use while, for, do while, whatever you prefer ;p
Creatures
Old September 23rd, 2008, 03:29 AM     #4 (permalink)
There are still problems in the number of 0's being appended.
Here are sample outputs:
4 = 0000100 (7 digits)
8 = 0001000 (7 digits)
16 = 00010000 (8 digits which is ok)
32 = 00100000 (ok again with 8 digits)
64= 001000000 (9 digits)
128 = 010000000 (9 digits)
255 = 011111111 (9 digits)
Old September 23rd, 2008, 04:47 AM     #5 (permalink)
Oh I got it to work by changing the for loop a bit:
int x = 5;
String str=Integer.toBinaryString(x);
for(int q=str.length();q<8;q++ ) {
str = "0" + str;
Old September 28th, 2008, 10:55 AM     #6 (permalink)
Rootstonian's Avatar
Glad you got...another method would have been to set an 8-byte array to all zeroes.
Then loop through storing remainder till number to convert is 0; then display array; display it backwards though (e.g. 128 bit value to 1 bit value). In C++:
Code:
#include <cstdlib>
#include <iostream>
using namespace std;
int main(int argc, char *argv[])
    int array[8] = {0,0,0,0,0,0,0,0};
    int i=0;
    int y;
    cout << "Enter number to convert (0 to 255): " ;
    cin >> y;
    while(y != 0) {
                array[i] = y % 2;
                i=i+1;
                y=y/2;
    for(int i=7;i>=0;i--)
      cout << array[i];
    cout << endl;
    system("PAUSE");
    return EXIT_SUCCESS;
Rootstonian is online now   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
binary to decimal in java omcmb Webmastering and Programming 6 September 21st, 2007 07:20 PM
Windows displaying problem hobo_man Technical Support 2 November 3rd, 2005 12:17 AM
binary to decimal in java jgargac Webmastering and Programming 8 April 25th, 2005 01:55 AM
Mandrake 8.1 Boots with 0's and 1's problem BostnBoy328 Technical Support 13 February 12th, 2002 12:37 AM
Mandrake 8.1 Boots with 0's and 1's problem BostnBoy328 Technical Support 1 December 27th, 2001 09:22 PM
Is It Just Me? (528)
Misery Loves Company... (1849)
Why Does the MOON Grow Bigger as It.. (18)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (14)
SSD's, RAID, and External Backup (7)
1 internet. 1 house. 3 computer. ho.. (13)
firewall (1)
C++ compiler suggestions (4)
Official World of Warcraft Thre.. (4529)
Programming question (2)
UPGRADING C/D DRIVE TO 250GB &a.. (14)
Ubuntu or Xubuntu....anyone!!? (7)
Building my first PC and need s.. (0)
PNY vs Gainward (3)
Linksys WRT54G (2)
