Join TechIMO for Free!
Thread Tools
Currently Active Users: 2526
Discussions: 186,605, Posts: 2,227,032, Members: 230,239
Old September 21st, 2008, 03:50 PM   Digg it!   #1 (permalink)
Java : Would like help in solving "programming exercises"
I would appreciate it if someone could help me. I've been given specific directions to write a "simple" program in Java, but I can't seem to get the results i desire.
Problem:
Write a program that encodes a string by replacing all letters "i" with "!" and all letters "s" with "$". Use the replace method. Demonstrate that you can correctly encode the string "Mississippi".
So I need to change "Mississippi" into "M!$$!$$!pp!", here's what I have to far:
Code:
import java.lang.String;
public class Mississippi
    public static void main (String[] args)
        String msp = "Mississippi";
        System.out.print (msp.replace ("i" , "!"));
Everything else I've tried wouldn't compile or didn't give me the solution I need, such as:
Code:
msp.replace ("i", "!");
System.out.print (msp);
Gives me "Mississippi"
or
System.out.print (msp.replace ("i" , "!") msp.replace ("s" , "$"));
I get a syntax error when compiling
or
System.out.print (msp.replace ("i" , "!");
System.out.print (msp.replace ("s" , "$");
Gives me "M!ss!ss!pp!Mi$$i$$ippi"
murakumo32 is offline   Reply With Quote
FREE instant scan
Old September 21st, 2008, 03:58 PM     #2 (permalink)
Go back to sleep
Creatures's Avatar
Send a message via ICQ to Creatures
well the best way to actually do this is to break the string apart and read every single letter at once and check if it's an s or a i and switch the letter if necessary
of course it uses more code but should work a lot better, i could give it a try, but my last java job was a game engine which had nothing to do with strings but if you want me to, i could wrap something up
Creatures
Knowledge Is Power
Creatures is offline   Reply With Quote
Old September 21st, 2008, 05:21 PM     #3 (permalink)
Go back to sleep
Creatures's Avatar
well replace should work ;P
Code:
   String str = "Mississippi";   //creating a string str containing "Mississippi"
   str = str.replace('i', '!');      //replacing i's with !'s and storing string in str
   str = str.replace('s', '$');    //replacing s's with $'s and storing string in str
   System.out.println(str);     //displaying str in console
used it like this and worked like a charm
you have to store your new string somewhere so you can modify it again, there is no way you can do this in one step.
Creatures
Old September 21st, 2008, 05:54 PM     #4 (permalink)
Thanks a bunch! I'll need to keep that "str = " in mind the next time a problem like this comes up.
Old September 24th, 2008, 03:11 PM     #5 (permalink)
Rootstonian's Avatar
"str =" is nothing special, just a name for a String variable; could have named it "String HermanMunster"
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
How do I disable the "power", "sleep", and "wake" buttons. ShawnD1 General Tech Discussion 1 January 30th, 2004 11:50 AM
IE not supporting "Java"?? Sweeper Technical Support 5 February 9th, 2003 01:54 PM
Remember the "Worm", "Cave", or "Ribbon" games? SickPup404 IMO Community 11 July 10th, 2002 08:02 PM
How to eliminate "java script error"?? chapmc Technical Support 4 April 8th, 2002 09:06 AM
Is It Just Me? (524)
Misery Loves Company... (1849)
Why Does the MOON Grow Bigger as It.. (17)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (13)
SSD's, RAID, and External Backup (7)
1 internet. 1 house. 3 computer. ho.. (13)
UPGRADING C/D DRIVE TO 250GB &a.. (13)
PNY vs Gainward (3)
Linksys WRT54G (2)
Contest: Logo and Banner design.. (0)
Hotmail Q (2)
SSD's, RAID, and External Backu.. (7)
Laptop doesn't stay connected t.. (7)
Computer won't start (4)
Official World of Warcraft Thre.. (4528)
