September 26th, 2008, 09:22 AM
| variable classes but same method
In JAVA I have 26 classes named A, B,.......,Y,Z. Each of them implements a method named Meth().
I have a String str that can contain the letter "A" or "B" or ....... or "Y" or "Z".
How can I implement the statement str.Meth();
so it will go to a different method depending on the value in str.
Thank you |
September 26th, 2008, 12:32 PM
| | Go back to sleep
so the methods do different things? or are the really the same just in different classes which seems to be kind of strange
could you state your problem, maybe there is a simpler or other way of solving it
Creatures
Knowledge Is Power
September 26th, 2008, 03:25 PM
The methods do different things depending on the class. I could use an IF ELSE construct and just list them all or use a SWITCH CASE construct but I am trying to do it in one statement. |
September 26th, 2008, 04:53 PM
| | Real gangstas sip on Yacc
So essentially you have Class1, Class2, Class3 all of which implement Meth()
You have a string that contains the name of a class.
So str = "Class3";
You want to turn something like Code: switch(str){
case "Class1":
Class1.Meth();
} Into a one line statement in Java?
Signatures blow hard
September 26th, 2008, 05:02 PM
September 26th, 2008, 05:12 PM
September 27th, 2008, 12:07 AM
| Sad but it didnt work.
When I tried
Object anObject = Class.forName("AK").newInstance();
anObject.Transform();
the compiler said "The method Transform() is undefined for the type Object ".
When I tried
((AK) anObject).Transform();
it compiled
When I tried
Class aClass = (Class) Class.forName("AK").newInstance();
aClass.Transform();
the compiler said "The method Transform() is undefined for the type Class".
When I tried
AK.Transform(); it compiled.
For some reason the class name must be mentioned. |
September 27th, 2008, 10:32 AM
Not 100% sure what you're trying to do??? So if str = A or B, you want to call A.Meth()???
Hmmm...seems to me when you instantiate the class, you'll have access to the correct Meth(); function; I just don't know what you're trying to do LOL
void main() {
A myClassA;
myClassA.Meth();
B myClassB;
myClassB.Meth();
// do you want this?
if(str == 'A')
myClassA.Meth();
September 27th, 2008, 10:26 PM
| Solution
To all those who gave suggestions a hearty thank you. The final solution was a follows:
An interface was set up.
package writeTextFile;
public interface WriteFile {
public void Transform();
All the classes implement the interface such as:
public class AK implements WriteFile
System.out.println("Went to AK");
return;
The 2 statements necessary to execute the transfer were:
WriteFile t = (WriteFile) Class.forName("writeTextFile." + state).newInstance();
t.Transform();
where the string state contained the 2 character class name.
The important but not obvious point was that the package name "writeTextFile" had to be included.
Thank you again for all your help. |
