Join TechIMO for Free!
Thread Tools
Currently Active Users: 2226
Discussions: 186,676, Posts: 2,227,797, Members: 230,320
Old October 13th, 2008, 03:03 PM   Digg it!   #1 (permalink)
bwcc's Avatar
VB/WMI help : copy files between 2 PCs
I'm having difficulty with my script which will should copy files between 2 different PC's.
Code:
strComputer = "."
set objFSO = CreateObject("Scripting.FileSystemObject")
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set colMonitoredEvents = objWMIService.ExecNotificationQuery _
    ("SELECT * FROM __InstanceCreationEvent WITHIN 10 WHERE " _
        & "Targetinstance ISA 'CIM_DirectoryContainsFile' and " _
            & "TargetInstance.GroupComponent= " _
                & "'Win32_Directory.Name=""\\\\\\\\data\\\\users\\\\test""'")
Do
    Set objLatestEvent = colMonitoredEvents.NextEvent
    strFile = objLatestEvent.TargetInstance.PartComponent
    strFile = Replace(Mid(strFile, InStr(strFile, Chr(34)) + 1), "\\", "\")
    strFile = Left(strFile, Len(strFile) - 1)
    objFSO.CopyFile strFile, "c:\test\"
Loop
Using the local connection above, it doesn't seem that I can use a UNC connection line in Win32_Directory.Name. However, if I change "\\\\\\\\data\\\\users\\\\test" to "Z:\\\\test" (by mapping \\data\users to Z: ), it will work fine. But I don't want to use mapped drive letters.
If I change strComputer to create a remote connection to the remote machine:
Code:
strComputer = "remotemachine"
                & "'Win32_Directory.Name=""c:\\\\test""'")
Do
    objFSO.CopyFile strFile, "\\data\test\"
Loop
The code runs fine until the loop, which returns a disk not ready error when it tries to copy the file. Permissions on \\data\test are set to Everyone - Full. I have also tried "\\data\users\test" and "\\data\c$\users\test\"
The end result I am looking for is:
Have a script run every so often on the server (data) and check for new files on 5 remote stations. If a new file is found, copy it to the server.
Any help on this would be appreciated.
TIA
Im against picketing, but I dont know how to show it.
bwcc is offline   Reply With Quote
FREE instant scan
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
no copy when move files c: -> d: JacobM5727 Technical Support 10 May 28th, 2008 07:21 AM
Some files can not be copy BluesMan1 Applications and Operating Systems 8 December 28th, 2005 10:27 AM
copy files from subdirectories? VHockey86 Applications and Operating Systems 4 May 12th, 2004 05:17 PM
Copy files from Red Hat to XP homerz Linux and Unix 7 October 25th, 2003 02:37 PM
copy files from CD to harddrive isup Storage Related 5 June 10th, 2003 11:04 PM
Is It Just Me? (654)
Best Boot Drive Imaging Software (7)
Video card compatability. (7)
File associations (5)
Bought an AGP "HIS Radeon HD 3.. (18)
Is this a good laptop for gamming? (6)
Outlook add-in won't remove. (10)
Presario Help (6)
Misery Loves Company... (1873)
graphics card driver issue (0)
What graphics card range for q9.. (1)
Can't print from IE7 (3)
Sidewindow for case (1)
Best Boot Drive Imaging Softwar.. (7)
*TechIMO's Top 30 PCs* (0)
Empire: Total War (6)
Advice needed for building a ga.. (7)
Seald copy of windows 95 for sa.. (1)
