Thread: MySQL Problems Assistance
February 2nd, 2009, 12:35 PM #1
Well, one of my databases for a website I maintain became corrupt last week due to something being jacked up on the host side. Well, my host did a free restore of my database to the night before the issues began occuring. Problem being I lost 3 days worth of important data. Well, I still have the old database, as they did the restore from backup to a new name. The host won't give me the raw data of the database so I can try to manipulate things on my end further. I tried doing a repair, export, etc and they all return the same error:
#1030 - Got error 1 from storage engine
I was wondering if any SQL guru's out there knew of some way to break the "In Use" on the database that isn't being used anymore and/or fix this error so that I can recover the 3 days worth of data that I'm missing. All I want to be able to do is look at 3 tables within this database and get about 20-30 lines from each table so I can input it manually into my new database.
Thanks in advance for your assistance, I've been googling for over an hour :/My Rig:
Intel Core 2 Duo E6600 @ 3.16||6GB OCZ Rev2 DDR2 800 @ 1:1 ratio
MSI 975X Platinum||GTX 275 896MB ||WD Black 640GB and 2x80GB RAID 0
February 2nd, 2009, 02:58 PM #2
Ok, I managed to convince them to give me all of the raw data files for the database..even after moving them over to the data directory, it doesn't see any of the innodb tables in there. So, after messing with it a bit, I've decided that I probably won't be able to simply mount and view, so I've decided to go another route with these. Anyone know if there's a way to simply view the information within the IBD files? I've tried excel and wordpad/notepad but they all have garbled information. Let me know if ya'll know of any way. Still googling :/
My Rig:
February 2nd, 2009, 08:25 PM #3
never mind...I kinda figured it out..I just used a hex editor to view the raw data files and although it looked ugly as hell, I was able to get what I needed from them and update the good database manually...thanks though
My Rig:
February 2nd, 2009, 08:27 PM #4
Sounds like it is time for a new host.
February 3rd, 2009, 07:22 PM #5My Rig:
February 3rd, 2009, 10:56 PM #6
If they do not allow you to export your MySQL data I would have left the second I received the backup after having to complain to them. It is YOUR data, not your hosts.
February 4th, 2009, 12:43 AM #7
no, that wasn't it. I couldn't do an export on the data because the database was corrupt. Neither could they. What they did was provide me with the ibd and frm files of the database itself. It's all good, though. Everything's back to how it should be so no worries
Have a good one.
My Rig:
February 4th, 2009, 01:26 AM #8
I see that's different.
need assistance!
By in-justice in forum Graphics Cards and DisplaysReplies: 2Last Post: December 22nd, 2007, 02:35 AM -
Car assistance
By Epidemic in forum IMO CommunityReplies: 13Last Post: May 1st, 2007, 12:56 AM -
FTP Assistance
By Melamorie in forum Networking and InternetReplies: 2Last Post: April 15th, 2007, 03:59 PM -
mySQL coding assistance
By herbal_lavender in forum Webmastering and ProgrammingReplies: 2Last Post: December 28th, 2005, 11:41 AM -
Need assistance
By Huntingdog in forum Networking and InternetReplies: 8Last Post: September 7th, 2004, 11:37 PM
One mess up in 4 years isn't too bad, in my opinion.
tend to run low on memory from time to time. I allowed an 8 gig RB drive. (formatted as exFAT)
