C and pointers help
Currently Active Users: 2508
Discussions: 201,011, Posts: 2,380,100, Members: 246,377
Old March 8th, 2009, 04:26 PM   Digg it!   #1 (permalink)
lost-and-found's Avatar
Send a message via AIM to lost-and-found
C and pointers help
Wow, it's been a while since I actually asked for help here, but here it goes.
I'm writing a C program that is using some pointers, pointers to pointers, etc.
Here's a small example of what my code needs to do
Code:
typedef struct{
  int num_tasks;
  int* task_list;   //a variable sized array of tasks
} entry;
typedef struct{
  entry *ref_to_entry;
} entry_node_t;
int main(){
  /* some code here that is irrelevant */
  entry *user_entry;
  user_entry = (entry*) malloc (num_entries*sizeof(entry)); //assume num_entries is obtained from user input during runtime
  entry_node_t* entry_node;
  entry_node = (entry_node_t*) malloc(num_entries * sizeof(entry_node_t));
  for(int i=0;i<num_entries;i++)
   entry_node = &user_entry[i];
Basically, in the above code I would like entry_node to be an array of pointers to each user_entry. I know I could just store the index to entry inside entry_node, but I would like it to be a pointer so that I don't have to write:
Code:
entry[entry_node[j]].num_tasks;
but instead use
Code:
entry_node[j]->num_tasks;
Am I doing something wrong? I try to compile and it compiles, but it doesn't seem to allocate space for entry_node.
lost-and-found is offline   Reply With Quote
Old March 15th, 2009, 11:30 AM     #2 (permalink)
Caveat Emptor
Rootstonian's Avatar
I forget the exact syntax, but can you try to "catch" the exception if malloc fails?
That one program way back when messed with my head too...an array of pointers to pointers...ugh! ROFL
Good Luck...if you need more help I will, but this stuff gives me headaches!!
I thought we coded something like: int **data_ptr;
c++ pointers lost-and-found Webmastering and Programming 5 August 23rd, 2004 09:21 PM
Pointers? Brainchild IMO Community 8 July 23rd, 2004 07:58 PM
C++ - Pointers and Practicality Iturea Webmastering and Programming 3 January 22nd, 2004 11:39 PM
Pointers as parameters...HELP! squeech Webmastering and Programming 1 September 16th, 2003 11:45 PM
C++ pointers Damien019 Webmastering and Programming 5 May 2nd, 2003 12:00 AM
Is It Just Me? (3137)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (6)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Please Help. (1)
winrar decompresses, but video gone (0)
Advice for stopping IRQ BSOD is win7 (0)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
