I am receiving an error when compiling and I do not understand why. Can anyone help out and let me know why this might be happening.
The error I am getting:
//ERROR: 'class' or 'interface' expected
the line error occurs is:
public static double getShortestWidth(MyRectangle r[])
Entire code:
import java.util.Scanner;
import java.util.Random;
import java.io.*;
public class PGM3
public static void main(String[] args) throws IOException
Printwriter pw; int c; MyRectangle [] x = new MyRectangle[20];
Scanner xyz = new Scanner(System.in);
System.out.println("Output filename? ");
fname = xyz.nextLine();
PrintWriter pw = new PrintWriter(fname);
for(c = 0; c<20; c++)
x[c] = new MyRectangle();
pw.println("Unsorted Rectangles Info\n");
writeMyRectangleInfo(x, pw);
pw.printf("\nShortest Length = %5.1f",getShortestLength(x));
pw.printf(" Longest Length = %5.1f",getLongestLength(x));
pw.printf("\nShortest Width = %5.1f".getShortestWidth(x));
pw.printf(" Longest Width = %5.1f\n",getLongestWidth(x));
MyRectangle y = getSmallestRectangle(x);
pw.printf("\nSmallest Area = %8.1f",y.getArea());
y = getLargestRectangle(x);
pw.printf("\nLargest Area = %8.1f",y.getArea());
selectionSort(x);
pw.printf("\n\n\nSorted Rectangles Info - In Ascending Order Of Area\n");
} //end of main
int startScan; int index; int minIndex; double minValue;
for(startScan = 0; startScan < (r.length-1); startScan++)
minIndex=startScan;
minValue=r[startScan].getWidth();
for(index = startScan + 1; index < r.length; index++)
if (r[index].getWidth() < minValue)
minValue = r[index].getWidth();
r[minIndex] = r[startScan];
r[startScan] = minValue;
return minValue;
public static double getLongestWidth(MyRectangle r[])
int startScan; int index; int minIndex; double maxValue;
minIndex = startScan;
maxValue = r[startScan].getWidth();
if(r[index].getWidth() > maxValue)
maxValue = r[index].getWidth();
r[startScan] = maxValue;
return maxValue;
public static double getShortestLength(MyRectangle r[])
minIndex=startScan;
minValue=r[startScan].getLength();
if (r[index].getLength() < minValue)
minValue = r[index].getLength();
return minValue;
public static double getLongestLength(MyRectangle r[])
maxValue = r[startScan].getLength();
if(r[index].getLength() > maxValue)
maxValue = r[index].getLength();
return maxValue;
public static void writeMyRectangleInfo(MyRectangle r[], PrintWriter y)
for(index = 0; index < r.length; index++)
System.out.print("Length: " + r[index].getLength());
System.out.print("\t\tWidth: " + r[index].getWidth());
double area;
area = length * width;
System.out.print("\t\tArea: " + r[index].getArea());
public static void selectionSort(MyRectangle[] array)
int startScan;
int index;
int minIndex;
int minValue;
for (startScan = 0; startScan < (array.length-1); startScan++)
minValue = array[startScan];
for(index = startScan + 1; index < array.length; index++)
if (array[index] < minValue)
minValue = array[index];
minIndex = index;
array[minIndex] = array[startScan];
array[startScan] = minValue;
public static MyRectangle getSmallestRectangle(MyRectangle x[])
minIndex=startScan;
minValue=r[startScan].getArea();
if (r[index].getArea() < minValue)
minValue = r[index].getArea();
return minValue;
public static MyRectangle getLargestRectangle(MyRectangle x[])
maxValue = r[startScan].getArea();
if(r[index].getArea() > maxValue)
maxValue = r[index].getArea();
return maxValue;
public class MyRectangle
Random r1 = new Random();
private double length, width;
public MyRectangle()
{ length = r1.nextInt(100)%10 + 10 + r1.nextDouble();
width = r1.nextInt(100)%10 + 5 + r1.nextDouble();
public void setLength(double len)
{ length = len; }
public void setWidth(double wid)
{ width = wid; }
public double getLength()
{ return length; }
public double getWidth()
{ return width; }
public double getArea()
{ return length * width; }
