Thread: Please Help
January 22nd, 2010, 07:14 PM #1Junior Member
- Jan 2010
- 1
Please Help
I'm creating a form for my website. I have a series of yes no questions with radio buttons. When the user clicks yes, I would like a text box to appear. Here is the code I'm using
/* CSS */
form input[name="text1"]
display: none;
/* SCRIPT */
<script type="text/javascript">
function checkIt(el) {
if (el.value == "other") {
document.forms['form1'].elements['text1'].style.display = "block";
else {
document.forms['form1'].elements['text1'].style.display = "none";
document.forms['form1'].elements['text1'].value = '';
</script>
/* MARKUP */
<form name="form1">
<input type="radio" name="radio" value="one" onclick="checkIt(this);">One
<input type="radio" name="radio" value="two" onclick="checkIt(this);">Two
<input type="radio" name="radio" value="other" onclick="checkIt(this);">Other<br>
<input type="text" name="text1" />
</form>
The issue being, it's not hiding the textbox when no is checked. Keep in mind this is a very small version of the code I'm using. If I have just one yes or no question it seems to work fine, it's when I add it to the other questions that I have problems.
Will I have to create different instance for each question to get this to work properly??
Use vinegar on your skin tonight and finish with 100% aloe vera lotion. My mom died this morning in her sleep. Just the way she would have wanted it, and while not quiet as soon as she wanted, it...
