Results 1 to 4 of 4
    Jun 2002
    6
    SubDomain help with IIS
    I created a subdomain, and linked it in inside the IIS manager. It works fine, here the problem ... I can view the subdomain page from the outside, but locally on the domain I cannot.
    How come?
    Xtreme Ultimate Member Mntsnow's Avatar
    Apr 1999
    NSL, Utah USA GMT -
    7,964
    Sounds like your internal DNS isnt updated correctly... What happens when you try to ping the subdomain? Does it time out/Unknown host/ or list the correct IP of the server?
    from the command prompt : ping subdomain.yourdomain.com <hit enter>
    -Mntsnow-
    Jun 2002
    6
    Smile Got it!
    It was the DNS, and I didn't have a Alias setup for the subdomain, therefore couldn't view it on the local domain.
    Apr 1999
    NSL, Utah USA GMT -
    7,964
    Glad it was an easy fix for you
