January 6th, 2012, 07:13 AM #1Junior Member
- Jan 2012
- 2
Java script countdown timer Nan Help pls!
I realy need some help i pass the end_time of the script using ajax from a database then calculate the remaining time calculating the dif from the current time each second. It works for the first second then I get NaN error + the timer then refreshes back to the first output in a countinous loop..
the contents of my timer where the js does its job
And the php that retrieves the time from the database (this file passes its info through ajax to the first code)Code:<html> <head> <script type="text/javascript"> var xmlhttp; var secs=0; var mins=0; var hours=0; var days=0; var t; function loadXMLDoc(url,cfunc) { if (window.XMLHttpRequest) {// code for IE7+, Firefox, Chrome, Opera, Safari xmlhttp=new XMLHttpRequest(); } else {// code for IE6, IE5 xmlhttp=new ActiveXObject("Microsoft.XMLHTTP"); } xmlhttp.onreadystatechange=cfunc; xmlhttp.open("GET",url,true); xmlhttp.send(); } function myFunction(actionvar) { var urlString = getHash(); var string = 'time.php?hash='+urlString+'&action='+actionvar; loadXMLDoc(string,function() { if (xmlhttp.readyState==4 && xmlhttp.status==200) { document.getElementById("timer").innerHTML=''; var end_time=xmlhttp.responseText; end_time = parseInt(end_time); end_time = end_time*1000; end_time = parseInt(end_time); update(end_time); var t = setTimeout(function(){myFunction(end_time);},1000); } }); } function getHash(){ return document.getElementById('hash').innerHTML; } function update(end_time){ out=""; var d=new Date(); end_time = parseInt(end_time); var time= parseInt(d.getTime()); var amount = end_time - time; // The time left in milliseconds amount = parseInt(amount); amount = Math.floor(amount/1000);//kill the "milliseconds" so just secs days=Math.floor(amount/86400);//days amount=amount%86400; hours=Math.floor(amount/3600);//hours amount=amount%3600; mins=Math.floor(amount/60);//minutes amount=amount%60; secs=Math.floor(amount);//seconds if(days != 0){out += days +" "+((days==1)?"day":"days")+", ";} if(hours != 0){out += hours +" "+((hours==1)?"hour":"hours")+", ";} out += mins +" "+((mins==1)?"min":"mins")+", "; out += secs +" "+((secs==1)?"sec":"secs")+", "; out = out.substr(0,out.length-2); document.getElementById('timer').innerHTML = out; if(secs == 0 && mins == 0 && hours==0 && days == 0){ clearTimeout(t); document.getElementById('timer').innerHTML='Boost ready'; } } </script> </head> <body style='background-image:url("main_bg.jpg");color:#580000'> <br /><br /><br /><br /><br /><br /><br /><br /><br /><br /><br /> <div id='timer' align='center'></div> <div align='center'> <?php require('global.php'); if(!isset($_SESSION['user'])){ header("Location: lol.php"); exit; } $id=$_SESSION['id']; $q= mysql_query("SELECT * FROM loltimerclient WHERE id='$id'"); $row = mysql_fetch_assoc($q); $hash=$row['hash']; echo "<div style='visibility:hidden' id='hash'>$hash</div>"; echo '<button type="button" onClick="myFunction(0)">Start timer NOW!</button>'; ?> </div> <div align='center'><a href='logout.php'>Logout</a></div> </body> </html>
Code:<?php require('global.php'); $hash = $_GET['hash']; $action = $_GET['action']; if(!isset($hash)|| !isset($action)) exit; $search_hash = mysql_query("SELECT * FROM loltimerclient WHERE hash='$hash' LIMIT 0,1"); if(mysql_num_rows($search_hash) < 1) exit; $row=mysql_fetch_assoc($search_hash); $id= $row['id']; $q = mysql_query("SELECT * FROM loltimers WHERE user_id='$id' LIMIT 0,1 "); $endtime = time() + (60*60*24); if($action == 0) if(mysql_num_rows($q) == 1){ mysql_query("UPDATE loltimers SET end_time='$endtime' WHERE user_id='$id'"); echo $endtime; } else{ if(mysql_num_rows($q) < 1){ mysql_query("INSERT INTO loltimers SET user_id='$id', end_time='$endtime' "); echo $endtime; } } else if($action == 1){ $row2=mysql_fetch_assoc($q); echo $row2['end_time']; } ?>
Any help is greatly appriciated since i can;t seem to figure this out.
Thx in advance!
January 6th, 2012, 08:10 AM #2Junior Member
- Jan 2012
- 2
nvm i found the problem where i stated
t = setTimeout(function(){myFunction(end_time);},1000) ;
should have been
t = setTimeout(function(){update(end_time);},1000);
and in the update i should recall the same setTimeout() in the else statement where i check if the time = 0
New question:
can anyone tell me why i can;t use sessions with ajax ? Apparently they will not work and i did start the session..
this is just for my knowlage i mannaged to find a workaround but still whould be nice to know why.
thx
What Java Script is this?
By Christato in forum Webmastering and ProgrammingReplies: 4Last Post: November 28th, 2008, 06:57 PM -
Karen's Countdown Timer II
By Marvinator in forum Applications and Operating SystemsReplies: 5Last Post: July 2nd, 2008, 06:52 PM -
countdown timer/ bootup
By ryanredbaron in forum Technical SupportReplies: 2Last Post: March 4th, 2005, 01:36 AM -
Java Countdown
By c6ke in forum Webmastering and ProgrammingReplies: 10Last Post: September 10th, 2003, 11:52 PM -
java countdown
By c6ke in forum Technical SupportReplies: 2Last Post: September 4th, 2003, 08:57 AM
Who would have imagined staid Geneva to be showing ...well to be hosting CooLCarZ > > > High-Performance in Geneva on MSN Photos I'm not sure what the "concept" is behind these "concept...
Sunday Morning in NY and GOOD...
