July 16th, 2002, 07:10 PM
| MySQL is busted, Need help backing up databases
Somehow my MySQL server got busted. None of the webpages are working that have to access it. Is there a way that I can back up the databases without having hte server working? Whenever I do anything on the command line I get this error: Code: ERROR 2002: Can't connect to local MySQL server through socket '/var/run/mysql/mys
ql.sock' (111)
Got root?
July 16th, 2002, 07:56 PM
ok i found out what was wrong. Once again my server was hacked. |
July 16th, 2002, 08:01 PM
lol...how did u get hacked and what did they do..
ummm
July 16th, 2002, 08:03 PM
well i found 2 files in my /var/tmp directory called elvis1.ses and elvis2.ses and they have some type of script in them that does something to mysql. How i got hacked is beyond me. I only have the ssh port open and a port open for apache and niether of them are the defualt port. |
July 16th, 2002, 10:37 PM
| | Xtreme Ultimate Member
|  so were you able to get MySql running again? You can do a "dirty" backup of the "DATA" directory which will have directories within it that actually have the individual database files.
-Mntsnow-
July 17th, 2002, 12:53 AM
| | Banned
| Quote: |
| which server??? DB,Web,App???
Are you trying to back up a DB, so when it gets 'hacked', you can restore?
should look into stopping hacks.
my bad... |
August 4th, 2002, 02:32 AM
On a side-side note...
1.) Look into tcp_wrappers (/etc/hosts.allow, /etc/hosts.deny)
2.) tar -cvf mysql-backup.tar /var/lib/mysql/
3.) You also might want to look into having MySQL only listen in localhost, and not any available interface. This can be done by adding "bind-address=127.0.0.1" (Without quotes) to your /etc/my.cnf (If you have one, since I don't know what distro you are on, etc) I do this, as a general security precaution to go along with #1
4.) Last but not least, can you paste those two Elvis session-history files? =] I'd be interested to see what they are trying to do.
*edit* I can't spell. |
August 5th, 2002, 10:05 AM
Actually I reinstalled the OS so I do not have those files anymore but it was on Slackware. |
