July 18th, 2002, 01:16 PM
| | Kawaru wa yo!
| Help: Print HTML docs w/VBA
Okay, here's the rundown, I've got a program that goes through an AutoCAD map and makes an HTML document list of all the data inside a certain block. What I would like to do is make a print function with the VBA that doesn't involve opening the page in a browser to print it AKA a print button.
So far, I've tried using the Microsoft Internet Controls reference, eg Code: Dim a as WebBrowser
a.Navigate sPath ' Path to HTML doc
a.??? There doesn't seem to be a print function like one would expect (or at least like I was lead to believe).
Anybody got any ideas?
-Whir |
July 18th, 2002, 01:40 PM
Well word can view html documents, have you tried using the word object? I would think it has a print method
Dim a as Application.Word I think it is? |
July 18th, 2002, 02:13 PM
| | Kawaru wa yo!
Okay, here's what I've got now:
Dim a as New Word.Document
a.Application.Document.Open sDocument
a.PrintOut
a.Close
This yields a blank sheet of paper, although it did, in fact, open the document in Word (since I had it open). I specified the filename after PrintOut also, and it still yields a blank sheet. Hard to find a descriptive help on this pile...
-Whir
Edit: So does:
a.ActiveWindows.PrintOut
Maybe there's a field I should be filling in for the function? It's a lot less than specific in the help.
July 18th, 2002, 02:38 PM
hmmm
maybe set a specific object for the document
Set doc = a.application.document.open sdocument
doc.printout ?? |
July 18th, 2002, 02:43 PM
| | Kawaru wa yo!
Tried that too. Miraculously this works for printing: Code: Private Sub CommandButton1_Click()
Dim a As New Word.Document
a.Application.Documents.Open "D:\Run\WI1471-1339.htm"
a.Application.PrintOut
a.Close
End Sub However... Unless the program has already run once, it won't close the program! I'm still playing with it, but so far not so good.
Then once I get it working, I need to make it print a whole direction. Fun with While Not.
-Whir |
July 18th, 2002, 03:17 PM
Hmm if this is going to do a lot of work, better hope for no memory leaks  I would assume there's a parameter you can pass to the open method so it doesn't show the GUI portion of WORD that would just get annoying and terribly slow.
Do you mean a whole directory?
If thats the case, then it gets easy you canjust use the folders and files collection in the scripting.filesystem object  |
July 18th, 2002, 03:22 PM
| | Kawaru wa yo!
Ya, I'm not really worried about the directory part. I just use sFile = Dir(*.htm) and While Not sFile = "".
I don't know if there's a setting to go non-GUI or not. If Word has opened once, it won't open the GUI, but if it's the first time, it opens it. Haven't been able to find a way to stop it yet. Argh.
Thanks for the help vass, wouldn't have gotten this far w/out it.
-Whir |
July 18th, 2002, 03:49 PM
| | Kawaru wa yo!
Well, you can do the Visible:=False, but it then it leaves WINDWORD.EXE sitting in memory, and keeps the file locked, even though I've done a close on it. The lock isn't a big deal, but I can't go leaving the Word executable open, eating up memory.  Arghness x 2.
-Whir |
July 18th, 2002, 04:08 PM
and if you
set a = nothing? |
July 18th, 2002, 04:23 PM
| | Kawaru wa yo!
Still leaves it open. I'm guessing because a = document, not the program itself. But if you do a as new Word.Application, there's no close method!
Maybe Word can be set up like AutoCAD so it's SDI and can only open one document at once? If you do a .close in MDI AutoCAD, it closes the map but leaves the program open. If you do a .close in SDI, it shuts down the program...
-Whir
Edit: Or I suppose I could use...
a.Application.Quit
<bashes head against desk>
Hah, get this, if I put that in there, it won't print!! It must send the quit too fast and not get the print command finished in time. Man this is just bizarre.
