Join TechIMO for Free!
Thread Tools
Currently Active Users: 2889
Discussions: 188,379, Posts: 2,243,461, Members: 232,607
Old August 4th, 2002, 12:11 AM   Digg it!   #1 (permalink)
Exclamation
Combo Boxes (Urgent Help required)
I'm still working on a database for my school library.
There are two combo boxes - Grade, Course.
The combo box Grade allows the operator to pick grades from 8 - 12.
The combo box Course allows the operator to pick four courses: A, B, C and D
All the grades (8,9,10,11,12) can do A or B
Only grade 10 can do C
Only grades 11 and 12 can do D
On my form when the operator chooses grade 8 from Grade, I want the combo box Course to only give the operator the options A and B NOT C or D.
Can someone pllllllllllllllllleeeeeeeeeasse help me...
shahzadsk
shahzadsk is offline   Reply With Quote
Old August 4th, 2002, 02:27 AM     #2 (permalink)
hmmm
well.. when you change the value in a combo box it calls an event
comboxbox_change() event
You could put code in there that says
Case 'A'
Case 'B'
combograde.add "A"
combograde.add "B"
Case 'c'
combograde.add C
well you get the point
not the greatest code in the world IMO but it'd work
vass0922 is online now   Reply With Quote
Old August 4th, 2002, 04:32 AM     #3 (permalink)
gettin late for me to do much right now, but maybe this will help somehow...
to delete an option, set it to null:
document.forms[0].name_of_select_box.options[index_of_option_to_delete] = null;
to add an option (adds it to the end of drpdown box):
document.forms[0].name_of_select_box.options[document.forms[0].name_of_select_box.options.length] = new Option("text", "value");
came from here basically...
ciao!
edit: can also use document.forms['form_name'] instead of document.forms[0], actually, I'd recommend it since it's safer, unless it's guaranteed to be only one form on the page...
^hyd^ is offline   Reply With Quote
Old August 4th, 2002, 09:07 AM     #4 (permalink)
I'll try them out.
Thanks..
Old August 4th, 2002, 11:43 AM     #5 (permalink)
hmm you never did specify what language you're working in
Old August 5th, 2002, 12:29 AM     #6 (permalink)
Sorry.. VB in Access 2000
Old August 5th, 2002, 12:33 AM     #7 (permalink)
Private Sub Grade_Click()
10: Course.AddItem "ACT"
Course.AddItem "IB"
Course.AddItem "IGCSE"
Course.AddItem "PNG"
Select Case (Grade)
Case "8"
Course.RemoveItem "IB"
Course.RemoveItem "IGCSE"
GoTo 10
Case "9"
GoTo 10
Case "10"
GoTo 10
Case "11"
GoTo 10
Case "12"
GoTo 10
End Select
End Sub
I used this but since it's a continuous loop it uses 99% of CPU power
Old August 5th, 2002, 12:34 AM     #8 (permalink)
So I tried this..
It works, but if I click on grade 10 and Igcse and then i click back on grade 8, it will accept grade 8 and IGCSE..which should not be accepted.. I want to run the code every second..
Private Sub Course_Click()
If Grade = "8" And Course = "IB" Then
GoTo 1
Else: GoTo 2
2: If Grade = "8" And Course = "IGCSE" Then
GoTo 1
Else: GoTo 3
3: If Grade = "9" And Course = "IB" Then
GoTo 1
Else: GoTo 4
4: If Grade = "9" And Course = "IGCSE" Then
GoTo 1
Else: GoTo 5
5: If Grade = "10" And Course = "IB" Then
MsgBox "Please select either ACT, IGCSE or PNG from the dropdown list."
Course = ""
GoTo 100
Else: GoTo 6
6: If Grade = "11" And Course = "IGCSE" Then
MsgBox "Please select ACT, IB or PNG from the dropdown list."
Course = ""
GoTo 100
Else: GoTo 7
7: If Grade = "12" And Course = "IGCSE" Then
Course = ""
GoTo 100
Else: GoTo 100
End If
End If
End If
End If
End If
End If
End If
1: MsgBox "Please choose either ACT or PNG from the dropdown list."
Course = ""
100: End Sub
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2885)
The United States Debt (20)
Looks like Burris will get his Sena.. (8)
Upgrading RAM (5)
Folderchat Weekday thread (439)
Antec 300 bulk purchase? (11)
Worth the upgrade?? (14)
Help with an Ati Radeon HD 4850 512.. (25)
Best digital camera for under 2.. (14)
Help with an Ati Radeon HD 4850.. (25)
Install Problem for Windows Def.. (0)
New Build ( Finally ) (1)
dual monitors wont boot (0)
MSN Hotmail Down??? (7)
Laptop waking up itself (0)
CPU wont boot (3)
Core 2 Quad Q9550 system (3)
