August 9th, 2002, 08:49 AM
Ok, I am running 98se..
I am having an odd problem ftping files to my site.
Randomly, it will lock up and stop transferring. I can hit ctrl-alt-del and restart it and continue but I have no clue what is causing it..
Not the ftp program 'cause I've tried three different ones..WSFTP, FTP Explorer and smart ftp...
any thoughts on this?? |
August 9th, 2002, 02:51 PM
I use 98se .... (and linux of course) ... and have noticed that after being installed for an extended period...(over 6 months... i can start having strange problems with the os... I usually just reinstall and everything goes okay again.
HTH's |
August 9th, 2002, 04:17 PM
Might be totally unrelated... But you could try reloading your Dial-Up Networking (Even if you don't use a dial-up) and reload your WinSock2 Reg entries..
(Check out http://www.crown.net/support/FixNoSurf.phtml for how to redo your Winsock reg)
*edit*
Also, you don't run any form of Firewalls, do you? (BlackIce, ZoneAlarm, ConSEAL, Norton Internet Security, etc) |
August 9th, 2002, 04:18 PM
ugh... I haven't done a reinstall in over 2 years probably.... I don't really wanna do that.....
no one else has some thoughts???
No one dies a virgin, Life screws us all.
August 9th, 2002, 08:57 PM
use NcFTP, if they make a windows version... |
August 10th, 2002, 02:24 AM
hmmm I forgot about zone alarm, I'll try disabling it and try that first.. |
