two small companies just merged, and you need to bring their home server directories onto your your home server directory
very common task.
Remember you can't necessariliy just copy them, you have to make sure the username exists on the new system, and if its not create it. Also have to make sure permissions are set correctly on the new server.
Or is that too much?
