Join TechIMO for Free!
Thread Tools
Currently Active Users: 2986
Discussions: 188,378, Posts: 2,243,448, Members: 232,606
Old November 5th, 2002, 04:01 PM   Digg it!   #1 (permalink)
ILC
ILC's Avatar
Strange problem
Needed to create a pointer based linked list, overloaded the += operator in my class to add a value to the list. The operator inserts the value in order.
It works fine until the first value entered is either 0 or 1. Notice, this is only a problem for the FIRST value entered. These numbers work fine at any other insertion point. Whats up, what am i obviously missing? Oh yea, I get a core dump when I try that.
Code:
bool Set::operator +=(const unsigned int value)
	bool retValue = false;
	//if value is not in the Set
	if(!(*this%value))           //% checks to see whether or not the value is already in the list
		if(head == NULL)		//add to empty list
			head = new Node;
			assert(head != NULL);
			head->next = NULL;
			head->dataValue = value;
			retValue = true;
		}//end of if - adding to empty list
		else					//else - multiple nodes
			Node *current = head;
			//value is less then the head
			if(value < current->dataValue)
				cout<<"else if"<<endl;
				current = new Node;
				assert(current!=NULL);
				current->dataValue = value;
				current->next = head;
				head = current;
				retValue = true;
			}//end if - value should be head
			else
				bool placed = false;
				Node *prev = current;
				current = current->next;
				if(placed == true)
					cout<<"true"<<endl;
				while(!placed)
					//value should be in center
					if((value > prev->dataValue)
						&&(value < current->dataValue))
						cout<<"while if"<<endl;
						current = new Node;
						current->next = prev->next;
						prev->next = current;
						placed=true;
						retValue = true;
					}//end if - value in center
					//value is at the end
					else if(current->next == NULL)
						cout<<"while else if"<<endl;
						prev = current;
						current = new Node;
						current->next = NULL;
						placed = true;
						retValue = true;
					}//end else if - add at end of Set
					//value should not be placed
					else
						cout<<"while else"<<endl;
						//increment pointers
						prev=current;
					}//end of else - not placed;
				}//end of while - placing value
			}//end of else - multiple nodes, not head
		}//end of else - multiple Nodes
	}//end of if - value is in the set
	return retValue;
}//end of operator +=
Thanks.
ILC
P.S. I know it isn't the prettiest code, but I despise pointers. Any cout statements were for trying to debug.
ILC is offline   Reply With Quote
Old November 5th, 2002, 10:50 PM     #2 (permalink)
ILC
ILC's Avatar
Well, several hours and aspirin later, I have fixed it. No one ask what exactly caused it becuase I myself am not too sure.......
ILC
Old November 7th, 2002, 12:57 AM     #3 (permalink)
so did you change anything in the code?
maybe we can see a difference...
vass0922 is online now   Reply With Quote
Old November 7th, 2002, 01:23 AM     #4 (permalink)
ILC
ILC's Avatar
Totally re-wrote the function.
Code:
bool Set::operator += (const unsigned int value)
	//if value is not in the list
	if(!(*this%value))
		if(head == NULL)
			head = addNewNode(value,NULL);
			retValue = true;
		}//end if - adding to empty list
		else if(value < head->dataValue)	//value should become the first node
			head = addNewNode(value,head);
			retValue = true;
		}//end else if - value should be first node
		else	//value in middle or end
			Node *current;
			Node *prev;
			current = head;
			bool run = true;
			//find location for pointer
			while(run)
				if((current->next == NULL)||(current->dataValue > value))
					run = false;
				else
					prev = current;
				}//end else
			}//end of while
			//add if needs to be last node
			if((current->next == NULL)&&(value > current->dataValue))
				current->next = addNewNode(value,NULL);
				retValue = true;
			}//end if - adding last node
			else
				prev->next = addNewNode(value,current);
				retValue=true;
			}//end of else
		}//end else - value not first
	}//end if - value in set
	return retValue;
}//end operator +=={
ILC
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2882)
The United States Debt (20)
Looks like Burris will get his Sena.. (7)
Upgrading RAM (5)
Folderchat Weekday thread (439)
Antec 300 bulk purchase? (11)
Worth the upgrade?? (14)
Titan quest and Immortal Throne, an.. (17)
dual monitors wont boot (0)
New Build ( Finally ) (0)
MSN Hotmail Down??? (7)
Help with an Ati Radeon HD 4850.. (23)
Laptop waking up itself (0)
CPU wont boot (3)
Best digital camera for under 2.. (13)
Building first computer, will t.. (2)
Core 2 Quad Q9550 system (3)
