Join TechIMO for Free!
Thread Tools
Currently Active Users: 3169
Discussions: 188,374, Posts: 2,243,436, Members: 232,603
Old November 6th, 2002, 08:05 AM   Digg it!   #1 (permalink)
Red face
problems with passing arrays of objects into functions
Alright, well, WHAT am I doing wrong???
I have "generalized" the code so that it doesn't have the technical details of the rest of the program with it, but I have narrowed down the problem to this.
Now this code will NOT even compile!!! What is wrong with it??? Keep in mind that it DOES compile if the if statement is left out, but that is checking to make sure there aren't any dangling pointers.
Code:
#include <stdlib.h>
struct structure{
     int a;
     int b;
     int c;
void func(structure* structs){
     for(int i=0; i<400; i++){
          if(structs[i] == NULL){
               //problem
          structs[i].a = 0;
          structs[i].b = 0;
          structs[i].c = 0;
int main(){
     structure structs[400];
     func(structs);
     return 0;
Jüš† ä €öm¶ù†Ê® §ÇÌÈñŒ mÅjÒ®
Jüš† ä gü¥ is offline   Reply With Quote
Old November 6th, 2002, 08:48 AM     #2 (permalink)
strangerstill's Avatar
Welll, structs is of type structure *
So structs[i] = *(struct + i) is of type structure
I'm guessing NULL is of type void * and has value 0.
So comparing structs[i] to NULL will crap out as you're comparing a structure to a pointer.
What you instead want is &structs[i] or, equivalently, just struct + i.
Which shows that the test you made is pointless, as there's no way that's going to equal (void *)(0).
Remember, C is perfectly happy indexing beyond the allocated bounds of an array - that's what a buffer overflow is.
strangerstill is offline   Reply With Quote
Old November 6th, 2002, 08:58 AM     #3 (permalink)
A better explanation is:
structure structs[400] allocates a memory block of length 400 * sizeof(structure) and sets structs to point to the beginning of that block.
Then an indexing operation structs[i] moves the pointer structs forward by i * sizeof(structure) and reads the memory from that location as a structure - that is, the first (sizeof int) bytes from ((void *) structs) + i * sizeof(structure) are read as structs[i].a, the next (sizeof int) bytes as structs[i].b, and the next (sizeof int) bytes as structs[i].c.
To get dangling pointers, you'd need to declare
Code:
structure *structs[400];
for (int i = 0; i < 400; i++) {
    structs[i] = malloc(sizeof structure);
where failure to perform the assignment to structs[i] would leave a dangling pointer (at least, you'd hope so - in fact, if structs[400] above does not have its memory region initialised to zeroes, then structs[i] could have any bytevalue and so point anywhere, giving you a GPF, segmentation fault or similar.
Old November 7th, 2002, 11:44 AM     #4 (permalink)
Another problem i see here is that "structure" hasn't been typdef'ed.
Thus you can't do:
and
but, must use:
struct structure structs[400]; /* say that 10 times fast */
and
void func(struct structure* structs){
alternatively, just make the typedef.
typedef struct{
int a;
int b;
int c;
} structure;
Aleph is offline   Reply With Quote
Old November 7th, 2002, 05:43 PM     #5 (permalink)
strangerstill, Thank you so VERY much!!!
That was EXACTLY what I needed to hear!!! You have given me the exact perfect solution and clearly illustrated to me EXACTLY what I was doing wrong, and EXACTLY what I should be doing instead.
Aleph, no, what you have suggested wasn't the problem, but thanks also for trying to help. I know that you are supposed to precede variable declarations which are declared as a structure with struct, however, on my particular compiler, and on many others, what I have done is allowed. The only time it becomes absolutely necessary to do that (in many cases) would be to avoid name clashes between similarly named structs and unions, or the like. Perhaps on your compiler, it is required.
Old November 7th, 2002, 06:09 PM     #6 (permalink)
nukes's Avatar
Send a message via AIM to nukes Send a message via Yahoo to nukes
Buffer overflows can be useful though.
You can push shellcode into the stack and badda-bing-badda-boom, you're in!
Obviously not as simple as that, take a look at phrack 49.
_____
NuKeS
nukes is offline   Reply With Quote
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2881)
The United States Debt (20)
Looks like Burris will get his Sena.. (7)
Upgrading RAM (5)
Folderchat Weekday thread (436)
Antec 300 bulk purchase? (11)
Worth the upgrade?? (14)
Titan quest and Immortal Throne, an.. (17)
Best digital camera for under 2.. (13)
Building first computer, will t.. (2)
Help with an Ati Radeon HD 4850.. (22)
CPU wont boot (2)
get this error, "res://C:\.. (73)
Problem with boot and motherboa.. (0)
MS to offer free Windows 7 upgr.. (1)
System Security Virus (20)
Core 2 Quad Q9550 system (3)
