November 7th, 2002, 04:24 AM
| SQL Help!!!!!
i have ms sql installed on my win 2k server and i am trying to set up the database on it i have created all the tables and set up logins but i can't find where to enter the data into? someone please help |
November 7th, 2002, 06:34 AM
ok if you want to enter the data like a spreadsheet and you have the tables created. You can right click on the table you want to enter data into and choose "Open Table" .. this will give you a spreadsheet type view.
OR another way... is to write up a sql script
-- this method requires inserting data for all columns...
INSERT INTO <tablename>
VALUES
(value1, value2, value3)
-- this method inserts data into the selected columns, but the columsn not mentioned but me nullable
(column1, column2, column3)
VALUES
(data1, data2, data3)
OR... if you have an existing spreadsheet out on a network or a drive, you can use DTS to extract the data...
lots of ways to do it ...
OR you couild write an application that does it from a form...
Oh btw, for using SQL code the easiest way to run it is from Query Analyzer. |
November 7th, 2002, 02:34 PM
how do i search for the information that i just entered? |
November 7th, 2002, 08:16 PM
it depends on what you're doing...
It sounds like you need to learn some SQL
here's a sql tutorial...
again you use it with the query analyzer. http://sqlcourse.com/intro.html  |
November 8th, 2002, 12:56 AM
thank you alot i read the learning sql server 2000 but it didn't help me much |
November 8th, 2002, 01:01 AM
My dilemna is, I can't tell you how to search for the data because I dont know your data.
You will start out with a select statement
select *
from <tablename>
then from there you can add a where clause
select *
from <tablename>
where <columnname> = 'some data'
just have to play around with it  |
November 8th, 2002, 01:05 AM
| | Kawaru wa yo!
<- Hates SQL.
SELECT * FROM 'Good Databases' Where 'Database Name' = 'Oracle9i Spatial' |
November 8th, 2002, 01:20 AM
I actually like SQL
course maybe that says something about me  |
November 8th, 2002, 04:23 PM
| sql web site
i now need to set up a web site to display information entered does anyone have a link to tutorial's or know how to do it? |
November 22nd, 2002, 03:59 AM
If you have MS Frontpage, the asp help for ata access is fairly decent. |
