Join TechIMO for Free!
Thread Tools
Currently Active Users: 3012
Discussions: 188,378, Posts: 2,243,447, Members: 232,605
Old November 11th, 2002, 01:34 PM   Digg it!   #1 (permalink)
Argon88's Avatar
Compiler problem
I down loaded the compiler Cev-C++ but I can't seem to get it to work. I tell it to compile and it appears to finish but when I tell it too run it says it isn't compiled and when I clikck the compile button again it says it's compiling. I've waited a least a half-hour for it to finish compiling, to no avail. Is it the compiler or me? I will admit I am very inexperienced at programing.
I'm trying to learn C++ but I'm having trouble. If you know of some good resorces for a beginer please tell me.
Argon88 is offline   Reply With Quote
Old November 11th, 2002, 10:15 PM     #2 (permalink)
ILC
ILC's Avatar
Where did you dl' it from? Give me the link so I can become a little familiar with the compiler. Also, give us the source code you are using and we can check over it to make sure it is not the source.
ILC
ILC is offline   Reply With Quote
Old November 11th, 2002, 10:32 PM     #3 (permalink)
Argon88's Avatar
I got it from www.bloodshed.net Strange name IMO. Maybe it got corrupted when I downloaded.
I was trying to compile Hello World. Told you I haven't gotten very far.
Old November 12th, 2002, 12:34 AM     #4 (permalink)
ILC
ILC's Avatar
Alright, I went ahead and downloaded DEV-C++ 6.0 BETA. Using the standard
Code:
#include <iostream.h>
#include <stdlib.h>
main()
cout<<”Hello World”<<endl;
system(“pause”);
return 0;
it compiled just fine (Execute->Compile). Went to run the program (execute->run) and I noticed that the window closed before you could view anything, therefore, I threw in the pause. As to why it will not compile, I am not sure. Perhaps you are compiling to one folder while the execution is looking in another?
Anyways, goodluck
ILC
P.S. I have several copies of Microsoft Visual C++ 6.0 Intro laying around. If you would like, PM me your address and I will send you a copy. Would be a much better compiler/interface to start out on.
Old November 12th, 2002, 06:34 PM     #5 (permalink)
I tried the bloodshed compiler on Win 98 - the os & the compiler didn't get along. MS visual C++ student version works fine.
fortysomething is offline   Reply With Quote
Old November 12th, 2002, 09:31 PM     #6 (permalink)
couch potato's Avatar
Wait, your inexperienced at programming, and you learning C++???? Or have you already learned C. If not, start with C. I'm just starting myself. Programming is fun
couch potato is offline   Reply With Quote
Old November 12th, 2002, 10:02 PM     #7 (permalink)
Argon88's Avatar
I checked my code and there was no problem there but it still did the same thing. I am runing it on Win 98 so maybe that's the problem. I'll try it on my comp, it's running under Win XP
And no, I have no previous programming experience. But why do you say I should learn C before C++? And yes, I agree, programming is fun and plus it pays well.
Old November 13th, 2002, 12:11 PM     #8 (permalink)
Argon88's Avatar
Okay, I tried it on my XP system and it worked, but only if I run it off the 98 to the XP over the LAN. If I installed it on the XP it wouldn't let me start a project.
Old November 13th, 2002, 04:41 PM     #9 (permalink)
ILC
ILC's Avatar
That's an odd problem.
I learned/am learning C++. Then I took come C, then went back to C++. Personally I really wouldn't worry much about C. I personally think it is easier to learn C++, then possibly switch to C if need be.
ILC
Old November 13th, 2002, 06:43 PM     #10 (permalink)
Here's a list of free compilers. The titles are links.
I hope you find something that works.
http://www.compilers.net/
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2882)
The United States Debt (20)
Looks like Burris will get his Sena.. (7)
Upgrading RAM (5)
Folderchat Weekday thread (439)
Antec 300 bulk purchase? (11)
Worth the upgrade?? (14)
Titan quest and Immortal Throne, an.. (17)
dual monitors wont boot (0)
New Build ( Finally ) (0)
MSN Hotmail Down??? (7)
Help with an Ati Radeon HD 4850.. (23)
Laptop waking up itself (0)
CPU wont boot (3)
Best digital camera for under 2.. (13)
Building first computer, will t.. (2)
Core 2 Quad Q9550 system (3)
