Help connecting .exe with this C++
Currently Active Users: 1828
Discussions: 200,979, Posts: 2,379,832, Members: 246,341
Old January 20th, 2003, 07:15 PM   Digg it!   #1
Banned
ok here is the deal,
i made that prog where you select a program from the list and click to run it and it opens it. Now i can open notepad, calculator and small stuff like that, but when i try to connect ot open my fifa2003.exe it doesnt work.
this is the typing i use. But it doesnt work.
// Did you user select to run the Fifa2003 program?
if (strPgmName == "FIFA2003")
// yes, run the Fifa2003 program
WinExec("fifa2003.exe",SW_SHOW);
BUT when i do this it works
// Did you user select to run the FNotepad program?
if (strPgmName == "NOTEPAD")
// yes, run the Notepad program
WinExec("notepad.exe",SW_SHOW);
Is it because i need to connect the fifa 2003 dll files to the progy or what is wrong to it.
Pickolizac is offline   Reply With Quote
Old January 20th, 2003, 07:20 PM     #2
Thaumaturge Member
howste's Avatar
I think you'll need to include the path to the executable file. Windows knows where calc.exe is, but not FIFA2003. Try this:
WinExec("C:\insertpathhere\fifa2003.exe",SW_SHOW);
howste is offline   Reply With Quote
Old January 20th, 2003, 11:48 PM     #3
Banned
thanks but it gives me this error
warning C4129: 'P' : unrecognized character escape sequence
its C:\Program Files\fifa2003.exe
any ideas?
Old January 20th, 2003, 11:51 PM     #4
Replace the \ with \\
Within a string literal, a single \ is considered to be an escape sequence, and the character that follows is considered to be a control character. So if you want a string to contain the character \, you need to replace it with \\ so that it will be interpreted correctly.
Martee is offline   Reply With Quote
Old January 21st, 2003, 12:20 AM     #5
Banned
Thanks to both of you, Martee that worked thank you so much, i really apreciate it. I just started playing with C++ few days ago for the hell of it, even though i wont need it till my senior year of college but i might take it in sophmore if it goes smoothly
Old January 21st, 2003, 11:18 PM     #6
Thaumaturge Member
howste's Avatar
Doh! I thought it would work that way since it's in quotes. Oh well, I don't know C++ anyway, so I don't feel too bad.
Charges against non-tippers dropped.. (19)
Health Care Rationing (9)
Is It Just Me? (3062)
Delete an OS (16)
Nvidia GTX 260 problem (9)
windows vista security holes (18)
Point and Shoot Camera Suggestions. (7)
Internet Lost (5)
Unallocated Space (0)
cheap gaming laptop? (11)
C# + LINQ Help (7)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (38)
Dynex DX E-402 (3)
Delete an OS (16)
cell phone won't work (0)
Can't open Word (12)
Open With ..... Win7 (3)
Internet Lost (5)
