ADO.NET and Relational Data problem.....how start?
Currently Active Users: 1971
Discussions: 200,511, Posts: 2,374,420, Members: 245,834
Old March 2nd, 2003, 05:10 PM   Digg it!   #1 (permalink)
Hi!
I will write an application that work with an Access DB.
My database have 5 table that have a relationship to each other.
tables in DB:
Table 1: Car: CarID, Manufactore, Colour, Hp, Displacement, Price, Model
Table 2: SaleContractCar: SaleContractID, CarID
Table 3: SaleContract: SaleContractID, CustomerID, Date
Table 4: Customer: CustomerID, CustomerAddressID, Tel, Age, SeconCar, Name
Table 5: CustomerAddress: CustomerAddressID, Street, StreetNr, Zip, City
relationship between the tables:
Table 1 (one to more) Table 2
Table 2 (more to one) Table 3
Table 3 (more to one) Table 4
Table 4 (more to one) Table 5
at this moment I don't know how to start.
should I first load all tables I one DataSet?
and create for each table a DataTable?
how I should start?
how I should write an update SQL statement for this DataSet?
where I can find some sample application that work with Relational Data?
thx!!
gicio is offline   Reply With Quote
Old March 3rd, 2003, 12:36 AM     #2 (permalink)
It depends on what you are looking to do with the data. One thing is, as far as the update statement, you really write it for the Data Adapter, not the DataSet. If you drop the Data Adapter onto the form, it will create the Update command for you, if it can (won't be able to if the underlying DB doesn't have a primary key).
I am thinking that you will be using this to enter in data, using parent/child data entry concepts. In the case of Access, this would be somewhat difficult for me as far as creating new records. If you entered a parent record, then wanted to add child records to it, you wouldn't know which record you created in the parent table. This is easily resolved in SQL Server using a stored procedure to get the ID back, but Access is different.
If I was you, I would use the Data Form Wizard and look at the code they generate, and use some of the concepts from that.
Creosote is offline   Reply With Quote
Old March 3rd, 2003, 03:55 PM     #3 (permalink)
thanks!!
another question: Is it possible to select all data from DB with one statement and fill the DataSet?
gicio
Old March 3rd, 2003, 08:56 PM     #4 (permalink)
That would depend on how the db is setup. If you used a Join statement to select it, then it probalby wouldn't be updatable. And you might not have proper columns to join some tables on as well.
Is It Just Me? (1637)
windows 7 retail and rtm (5)
Review My Build (6)
Assosiations (21498)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
