need perl help
Currently Active Users: 2707
Discussions: 200,965, Posts: 2,379,621, Members: 246,332
Old March 4th, 2003, 03:19 PM   Digg it!   #1 (permalink)
need perl help
Hi, I'm new to this message board, and I suck at perl, so if anybody could help, it would be much appreciated.
OK, here's my problem.
I have a list of data in an input file that looks like this:
iep184:30201:222::/showme4/iep184:/usr/lbin/tcsh
The first portion, the iep184 part, is the user ID. I need to go through the list and get all user IDs that start with 'c' and end with '1'.
Any ideas? I think I have to use a split of some sort, but I'm not really sure how that works. Thanks for any help.
thelactator is offline   Reply With Quote
Old March 4th, 2003, 04:31 PM     #2 (permalink)
may contain mild peril
SpookyEddy's Avatar
Sounds like you have the general idea, you could just split the line around : and then check the first field against a simple regexp to see if it matches you criteria. I can hack together some super ugly code for you when I get home if you want, but be warned that I also suck at Perl
Regards
eddy
I dreamt that a large eagle circled the room three times and then got into bed with me and took all the blankets.
SpookyEddy is offline   Reply With Quote
Old March 4th, 2003, 05:58 PM     #3 (permalink)
SpookyEddy's Avatar
Ok first quick attempt that seems to basically work, but I could be horribly wrong (so please test on a non important file).
Code:
#!/usr/bin/perl -w
#### DISCLAIMER ###############
# Standard warnings, blah blah
# This code was written by a man with the IQ of a punch drunk monkey.
# I accept no responsibility for loss of data, life or sanity.
use strict;
my $usage = <<EOT;
Usage: $0 [filename]
EOT
#do some rather shody checking on no. of args
if (@ARGV != 1) { die $usage }
my $file = shift;
#open an input file
open(FILE, $file) or die "Can't open input: $!";
#step over each line in the file
while(<FILE>){
        #split line up into an array
	my @line= split(/:/, $_);
        #print first element of array if it matches regexp
	if($line[0] =~ /^c(.*)1$/){ print "$line[0]\n" }
#Tidy up after reading
close(FILE);
#### The madness ends here ####
I will spend a few minutes later cleaning it up a bit and hunting down any major bugs, but you get the general idea.
Regards
eddy
Old March 4th, 2003, 06:11 PM     #4 (permalink)
Damn....you kick ass man...I can't thank you enough. One question, what does EOT do? Thanks again.
Old March 4th, 2003, 06:16 PM     #5 (permalink)
SpookyEddy's Avatar
It just lets me read all the info before the last EOT into the variable, handy for writing stuff like multi-line help info you want printing to STDOUT. This would work just as well.....
Code:
my $usage = "Usage: $0 [filename]"
Anyway, hope it works and you are more than welcome. Any problems just shout and I will see if I can fix it.
Later
eddy
Old March 4th, 2003, 06:22 PM     #6 (permalink)
kick ass and chew bubblegum...thanks again mon frere.
Forty-six years ago today (5)
Is It Just Me? (3006)
Laptop with wireless problem. (11)
Internet Lost (5)
windows vista security holes (14)
Print spooler problem (16)
Open With ..... Win7 (2)
Internet Lost (5)
NO GAS (0)
Help getting around port 80 for camer.. (3)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
