Help with 'sliding' menu
Currently Active Users: 1811
Discussions: 200,923, Posts: 2,379,103, Members: 246,290
Old March 14th, 2003, 04:19 PM   Digg it!   #1 (permalink)
SaTaNcLaUz's Avatar
HI everyone!
Quick question. www.microsoft.com , see the little black pop-down menu thingy in the top right corner? the one with the curve on the left side? (all products | support | search | ...)
how the **** do they do that?!?!?!?
I see in the source its javascript but is there a way to do it in Dreamweaver or Fireworks? (i have them both) I can get the pop-up menu's to work but how do I make it slide with the screen size?
if there is a way I sure cant figure it out! lol!
anyone know if there is anything I can do with DW or FW??
thx,
Rob
SaTaNcLaUz is offline   Reply With Quote
Old March 15th, 2003, 03:30 PM     #2 (permalink)
Per aspera ad astra!
Socalgal's Avatar
i think this might be it..
http://www.js-examples.com/example/?ex=196
oh.. forgot to say, if you download the entire page, you should be able to get source code/files to recreate the menu, adding your own changes ...
Socalgal is offline   Reply With Quote
Old March 17th, 2003, 08:15 AM     #3 (permalink)
SaTaNcLaUz's Avatar
ah thats perfect! thanks TechIMO Chick!
Is It Just Me? (2856)
Obama the Muslim (13)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
