Join TechIMO for Free!
Thread Tools
Currently Active Users: 2747
Discussions: 188,383, Posts: 2,243,484, Members: 232,612
Old April 24th, 2003, 10:33 PM   Digg it!   #1 (permalink)
tenor_david's Avatar
Hey, I need Java Help too!
Hey all, how can I convert this code into an applet, rather than a JFrame? I am seriously DISliking Java right now.....
Code:
import javax.swing.*;
import java.awt.*;
import java.awt.event.*;
import java.util.*;
 * NewsSearchTest.java
 * Created on April 24, 2003, 7:08 PM
 * @author  Ray Household
public class NewsSearchTest extends JFrame {
    private JLabel nyLabel;
    private JTextField nyKeyword;
    private Container searchArticles;
    private JButton beginSearch;
    private JTextArea output;
    public NewsSearchTest()
        nyLabel = new JLabel("Enter Keywords");
        nyKeyword = new JTextField( 15 );
        beginSearch = new JButton( "Search" );
        beginSearch.addActionListener(
            new ActionListener() {
                   public void actionPerformed( ActionEvent e )
                      StringTokenizer tokens = new StringTokenizer( nyKeyword.getText() );
                        output.setText( "Number " + tokens.countTokens() + "." );
                        while ( tokens.hasMoreTokens() )
                            output.append( tokens.nextToken() + "\n" );
        Container searchArticles = getContentPane();
        searchArticles.setLayout( new FlowLayout() );
        searchArticles.add( nyLabel );
        searchArticles.add( nyKeyword );
        searchArticles.add( beginSearch );
        output = new JTextArea( 10, 20 );
        output.setEditable( false );
        searchArticles.add( new JScrollPane( output ) );
        setSize( 275, 240 );
        setVisible( true );
    /** Creates a new instance of NewsSearchTest */
    public static void main( String args[] )
        NewsSearchTest application = new NewsSearchTest();
        application.setDefaultCloseOperation( JFrame.EXIT_ON_CLOSE );
tenor_david is offline   Reply With Quote
Old April 25th, 2003, 12:49 AM     #2 (permalink)
DJDaveMark's Avatar
Here's a funky way, but probably not what you want. I'll post the better way in a minute
Code:
import java.applet.Applet;
public class AppAsApplet extends Applet
    public void init()
        add(new NewsSearchTest());
You may need to refer to one of my posts in this forum http://www.techimo.com/forum/showthr...301#post592301 to make sure if your putting your applet on the web it's available to all.
DJDaveMark is offline   Reply With Quote
Old April 25th, 2003, 03:03 AM     #3 (permalink)
Thanks for the info. I started over from scratch and am having reasonable success.
Here is a question, how do you extract a 'value' from a RadioButtoinGroup?
I have 3 buttons, 'AND' 'OR' 'NOT'.
How can I get the actual 'value' of the selected radiobutton after pressing a 'SEARCH' button?
Old April 25th, 2003, 03:54 AM     #4 (permalink)
DJDaveMark's Avatar
Here's your App as an Applet
Code:
import java.awt.*;
import java.util.*;
 * @modified 25/04/2003 DaveMark : from App 2 Applet!
class NewsSearchTest extends JApplet implements ActionListener {
    private Container cp;
    public void init()
        nyLabel = new JLabel( "Enter Keywords" );
        beginSearch.addActionListener( this );
        beginSearch.setMnemonic(KeyEvent.VK_S);
        cp = getContentPane();
        cp.setLayout( new FlowLayout() );
        cp.add( nyLabel );
        cp.add( nyKeyword );
        cp.add( beginSearch );
        cp.add( new JScrollPane(output) );
        output.setText( "Number = " + tokens.countTokens()
                                    + "\n------------\n" );
     * Bung the JApplet in a JFrame and call the init() & start methods
    public static void main(String [] args)
        NewsSearchTest nst = new NewsSearchTest();
        nst.init();
        nst.start();
        JFrame.setDefaultLookAndFeelDecorated(true);
        JFrame f = new JFrame();
        f.getContentPane().add(nst);
        f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
        f.setSize(300, 300);
        f.setLocation(300, 300);
        f.setResizable(false);
        f.setVisible(true);
It's easier to design an Applet then add a main method if you want to use or test it as an App. The main method would instantiate the Applet, add it to a frame and explicitly call the init() & start() methods. This wouldn't affect the class still being able to work as an Applet! I'll edit this post l8r to show that in action.
Doing it from App 2 Applet usually means reworking most of the code!
[edit] I've now added the main method to the JApplet class so the
same code will run as an Applet and a standalone Application!
[/edit]
Old April 25th, 2003, 05:11 AM     #5 (permalink)
DJDaveMark's Avatar
Here you go....
Code:
import java.awt.*;
class RadioBtns implements ItemListener
    public void doGUI()
        CheckboxGroup radios = new CheckboxGroup();
        Checkbox cb1 = new Checkbox("AND", radios, true);
        Checkbox cb2 = new Checkbox("OR", radios, false);
        Checkbox cb3 = new Checkbox("NOT", radios, false);
        cb1.addItemListener(this);
        cb2.addItemListener(this);
        cb3.addItemListener(this);
        JFrame f = new JFrame("Radio Buttons");
        Container cp = f.getContentPane();
        cp.setLayout(new FlowLayout());
        cp.add(cb1);
        cp.add(cb2);
        cp.add(cb3);
        f.addWindowListener(new WindowAdapter() {
            public void windowClosing(WindowEvent e)
            { System.exit(0); }
        f.setSize(400, 100);
        f.setVisible(true);
    public void itemStateChanged(ItemEvent event)
        if (event.getStateChange() == ItemEvent.SELECTED)
            System.out.println("`" + event.getItem() + "' selected!");
        new RadioBtns().doGUI(); //instantiate and call a method
You could also......
button.setActionCommand("WhateverString");
then query it by......
if (event.getActionCommand() == "WhateverString");
Old April 25th, 2003, 07:25 AM     #6 (permalink)
DJDaveMark's Avatar
Here's the same thing using the setActionCommand() but with a cool look & feel.
Code:
import java.awt.*;
class RadioBtns implements ActionListener
    String strAND = "AND",
           strOR  = "OR" ,
           strNOT = "NOT";
    public void doGUI()
        ButtonGroup grp = new ButtonGroup();
        JRadioButton rb1 = new JRadioButton(strAND);
        JRadioButton rb2 = new JRadioButton(strOR);
        JRadioButton rb3 = new JRadioButton(strNOT);
        grp.add(rb1);
        grp.add(rb2);
        grp.add(rb3);
        rb1.setActionCommand(strAND);
        rb2.setActionCommand(strOR);
        rb3.setActionCommand(strNOT);
        rb1.setMnemonic(KeyEvent.VK_A);
        rb2.setMnemonic(KeyEvent.VK_O);
        rb3.setMnemonic(KeyEvent.VK_N);
        rb1.addActionListener(this);
        rb2.addActionListener(this);
        rb3.addActionListener(this);
        rb1.setSelected(true);
        cp.add(rb1);
        cp.add(rb2);
        cp.add(rb3);
        f.setVisible(true);
    public void actionPerformed(ActionEvent event)
        System.out.println("`" + event.getActionCommand() + "' selected!");
Old April 25th, 2003, 11:04 AM     #7 (permalink)
Very much appreciated! Thanks!
Old April 25th, 2003, 10:46 PM     #8 (permalink)
DJDaveMark's Avatar
Nae Bother tenor,
I've added a main method to your App as Applet class, so the same class functions as both an Applet and a stand-alone App. http://www.techimo.com/forum/showthr...029#post641029
Choi 4 now!
Old April 27th, 2003, 03:10 PM     #9 (permalink)
Hey there DJDaveMark:
I am going to pick your brain again!
Here is the current status of this project I am working on:
http://mentor.ucs.indiana.edu/~s3jm0...chGridBag.html
The only listeners I have succesfully implemented till now are the listeners that write the 2 text fields to the JScrollPane Text Area.
I cannot seem to get the radio button listeners working correctly. Basically, when a user submits a search, the history panel should display: keywords1 + searchLogic + keywords2 + \n
Eventually, we will actually send the search parameters to the appropriate engine and return the results in a pop up window.
Any help w/ the radio button listener would be much appreciated
Search Interface Source
Date Combo Box Source
Old April 27th, 2003, 10:44 PM     #10 (permalink)
DJDaveMark's Avatar
'lo again tenor,
You were so, so close yet that cigar eluded you!
You were only really missing two lines of code. One to get the info & the other to append to the history. You don't need to implement any listeners for the JRadioButtons. When the Search button is clicked you just need to interogate which JRadioButton is selected.....so from this......
Code:
//START DM EDIT ===============================
        nySearch.setText("Search");
        nySearch.addActionListener(new java.awt.event.ActionListener() {
            public void actionPerformed(java.awt.event.ActionEvent evt) {
                nySearchHandler(); //no need to pass in ActionEvent
                //mySearchHandlerLogic();
                //mySearchHandler2();
//END DM EDIT ===============================
......you call this........
Code:
    private void nySearchHandler() {//GEN-FIRST:event_nySearchHandler
        StringTokenizer tokens = new StringTokenizer( nyKeywords.getText() );
                            historyText.append( tokens.nextToken() + " " );
        ButtonModel logicBtn = searchLogic.getSelection();
        historyText.append( logicBtn.getActionCommand() + " " );
        //mySearchHandler2
        StringTokenizer tokens2 = new StringTokenizer( nyKeywords2.getText() );
                        while ( tokens2.hasMoreTokens() )
                            historyText.append( tokens2.nextToken() + " ");
                        historyText.append( "\n" );
    }//GEN-LAST:event_nySearchHandler
Also, did you know you named one method "nySearchHandler" with an 'n' and "mySearchHandler2" with an 'm'
The key to the above part working relies on using the setActionCommand(java.lang.String) method correctly.....like so
Code:
        logicPanel.setMinimumSize(new java.awt.Dimension(300, 34));
        logicPanel.setPreferredSize(new java.awt.Dimension(300, 34));
        andLogic.setMnemonic('A');
        searchLogic.add(andLogic);
        andLogic.setActionCommand(strAND);
        andLogic.setLabel(strAND);
        logicPanel.add(andLogic);
        notLogic.setMnemonic('N');
        notLogic.setText(strNOT);
        searchLogic.add(notLogic);
        notLogic.setActionCommand(strNOT);
        logicPanel.add(notLogic);
        orLogic.setMnemonic('O');
        orLogic.setText(strOR);
        searchLogic.add(orLogic);
        orLogic.setActionCommand(strOR);
        logicPanel.add(orLogic);
        //andLogic.setSelected(true);
The setActionCommand(java.lang.String) doesn't have to be the same String as the label, it can be any text string imaginable. I used the strAND strNOT strOR just so i didn't miss spell the label from the actionCommand and would only need to update the text in one place if it changed. (I also had to move their String declarations from the constructor method to the class level beside the other class variables)
The only problem I can now see is when you click the search button without selecting AND/OR/NOT. I tried to use andLogic.setSelected(true); but it didn't work for some reason and i've left it in but commented out. I can't see anything in your code that would conflict with it, and don't know why this is happening. I even tried setting the name and default state of the JRadioButton using it's constructor methods but this didn't work as it should have either.
Anyway, if all else fails you could always error trap this in the nySearchHandler() method. I'm sure you've lots to get on with now!!!
EDIT: Wait a minute, I don't know how I missed this, but you're using a constructor method to initialize your Applet. Here's a quote from the java.sun.com website
fromhttp://java.sun.com/docs/books/tutor...etMethods.html
The init method is useful for one-time initialization that doesn't take very long. In general, the init method should contain the code that you would normally put into a constructor. The reason applets shouldn't usually have constructors is that an applet isn't guaranteed to have a full environment until its init method is called. For example, the Applet image loading methods simply don't work inside of a applet constructor. The init method, on the other hand, is a great place to call the image loading methods, since the methods return quickly. Every applet that does something after initialization (except in direct response to user actions) must override the start method. The start method either performs the applet's work or (more likely) starts up one or more threads to perform the work
That could be a contributor to the setSelected(true) trouble
Cheery-Bye
DaveMark
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2888)
The United States Debt (20)
Looks like Burris will get his Sena.. (8)
Upgrading RAM (5)
hp compaq nc6000 problems (138)
Folderchat Weekday thread (440)
Antec 300 bulk purchase? (11)
Help with an Ati Radeon HD 4850 512.. (27)
ADVICE (0)
How to increase my ram? (5)
Building a gaming computer advi.. (2)
Help with an Ati Radeon HD 4850.. (27)
CPU wont boot (4)
2nd video card (1)
special characters in quarkxpre.. (3)
Need help removing my front usb.. (2)
Core 2 Quad Q9550 system (3)
