Results 1 to 15 of 15
    addicted DVNT1's Avatar
    Ohio
    6,103
    need VBS script (pausing issue)
    I have a script that deletes old user profiles (older than 90 days) on AD Domain computers.
    set wshshell = createobject("WScript.Shell")
    Const ADS_SCOPE_SUBTREE = 2
    Set objConnection = CreateObject("ADODB.Connection")
    Set objCommand = CreateObject("ADODB.Command")
    objConnection.Provider = "ADsDSOObject"
    objConnection.Open "Active Directory Provider"
    Set objCOmmand.ActiveConnection = objConnection
    objCommand.CommandText = _
    "Select Name, Location from 'LDAP://ou=test,DC=mydomain,DC=com' " _
    & "where objectClass='computer'"
    objCommand.Properties("Page Size") = 1000
    objCommand.Properties("Timeout") = 30
    objCommand.Properties("Searchscope") = ADS_SCOPE_SUBTREE
    objCommand.Properties("Cache Results") = False
    Set objRecordSet = objCommand.Execute
    objRecordSet.MoveFirst
    Do Until objRecordSet.EOF
    Wscript.Echo "Computer Name: " & objRecordSet.Fields("Name").Value & " Location: " & objRecordSet.Fields("Location").Value
    wshshell.run "delprof.exe" & " /q /i /c:\\" & objRecordSet.Fields("Name").Value & " /d:90"
    objRecordSet.MoveNext
    Loop
    My current problem: without the Wscript.Echo line, the script runs so fast multiple CMD windows are opened (one for each machine). To be more useful, I need a way to pause & then resume the script when the current computer is done.
    Suggestions?
    Not Really a Member
    27,856
    WScript.SLeep is what you need I do believe
    WScript.Sleep 6000 will wait a second before continuing
    (its in milliseconds so you can judge how long it needs)
    Just put it in place of the wscript if you want or just after it
    This a script of your own doing?
    Try code tags,they keep the indenting
    Ohio
    6,103
    If WScript.SLeep is strictly time based it would help but would not be ideal. Some machines take a long time, others a short time.
    I'm not sure what you mean by code tags. I have indenting on the real script but must have lost it with cut, paste, & post.
    not entirely, I started with a piece and kept adding stuff. I mostly combine script samples I find.
    Not Really a Member
    27,856
    hmmm
    OK .. well instead of calling the delprof.exe, you could call a batch file.. the batch file drops a flag file, calls delprof.exe and deletes it after running.
    The script after executing the batch continually checks for the flag file, once its deleted then move forward...
    Would that work out better?
    btw, I meant use the [ code ] tag instead of the [ quote ] tags
    Banned qball's Avatar
    447
    you have a timing issue. pausing is for timing issues to catch up...
    welcome to synchronous vs. asynchronous processing/programming/whatever...
    You seem to invoke:
    "wshshell.run "delprof.exe" "
    for each record in:
    "Do Until objRecordSet.EOF"
    But the script processes:
    without waiting (pause) until each:
    is completed.
    What do you gain by this?
    What are you trying to accomplish?
    Ohio
    6,103
    Vass: that idea should work fine. Now I would just need to figure out how to make that check flag file looping part.
    qball: The generic pausing just won't well because some machines will not need any pause, others may need minutes. Doing this for hundreds of workstations would be inefficient.
    What I gain & accomplish, this is to delete old unused local profiles off user workstations.
    Not Really a Member
    27,856
    add this to the declarations
    Dim objFSO
    Set objFSO = CreateObject("Scripting.FileSystemObject")
    Then just put this AFTER the call to the batch file
    Code:
    '' Keep waiting until the flag file is deleted through the batch file
    Do While objFSO.FileExists("\\pathto\file\flagfile.txt")
      ' ZZzzzzzzz
      WScript.Sleep 500
    Loop
    Note: Hopefully not necessary, but the script may be able to continue working past the loop faster than the batch file can create the text file so maybe required to put in a small sleep statement after the call to the batch file to give it a split second to work
    Are you going to be calling this from a logon script?
    Seems like this is going to NAIL your DC if 50 people all log on at roughly the same time especially if you have a large userbase.
    Ohio
    6,103
    That looks good!
    I won't do it via login script because users would need higher priviledges. I plan to have a Task on a DC or other server that does this once a month or something like that. The first time will be lengthy but after that it shouldn't be too bad.
    Ohio
    6,103
    It works as needed! End result requires these two files plus delprof.exe from MS Resource kit.
    main script:
    Code:
    Dim objFSO
    Dim strFilePath 'Path to current directory
    strFilePath = objFSO.GetAbsolutePathName(".")
    flagfile1 = strFilePath & "\flag1.txt"
    "Select Name, Location from 'LDAP://ou=myOU,DC=myDomain,DC=com' " _
    ''Next line is just an optional visual display of workstations found
    'Wscript.Echo "Computer Name: " & objRecordSet.Fields("Name").Value & "  Location: " & objRecordSet.Fields("Location").Value
    wshshell.run "delprof.bat " & objRecordSet.Fields("Name").Value
    WScript.Sleep 2000
    Do While objFSO.FileExists (flagfile1)
      ' ZZzzzzzzz
      WScript.Sleep 500
    Loop
    Loop
    delprof.bat contains:
    Code:
    echo just a temp file >flag1.txt
    delprof.exe /q /i /c:\\%1 /d:90
    del flag1.txt
    exit
    Thanks for all the help Vass!
    Not Really a Member
    27,856
    Excellent work, well you're doing the hard part I'm just helpin' ya tie up the loose ends now
    Good job
    447
    I understand. some milliseconds, others days...
    Your missing the point, but using the ability of a DOS batch file to run synchronously, to get around the inability for:
    "wshshell.run "delprof.bat " & objRecordSet.Fields("Name").Value"
    to run synchronously.
    Think about what you are doing:
    Looping through records to delete user profiles.
    Looping thru recs, no problem, deleting user profiles has timing problems.
    Your solution:
    Retrieve records and loop, del profile using batch file that effectively creates a flag file. Wait for file to not exist, process next record. That is barely efficient.
    Code:
    WScript.Sleep 2000
      ' ZZzzzzzzz
      WScript.Sleep 500
    Loop
    Loop
    Is useless code if one just does:
    Retrieve records and loop.
    del profile using synchronous method, perhaps winAPI call to delete profile, not command line exe?
    Seems silly to use exe from resource kit to accomplish core OS maintenance...
    Ohio
    6,103
    qball: If you know how to "del profile using synchronous method, perhaps winAPI call to delete profile" I'm quite interested in hearing how. I'm not a programmer by any means, I just needed a way to do this maintenance.
    When I say more efficient, I meant as opposed to what I had figured out so far.
    You post seems more like an attempt to be disrepectful than to help. I hope you prove this feeling wrong by offering an improvement or working alternate solution.
    447
    My bad. Any disrespect is the reality of the situation.
    Couple of questions:
    How do you add profiles (or user?)?
    what profile (and priviliges) does the 'script' that calls:
    run under?
    If you don't like my answers, ask better questions. Or ask your winders admin, how to remove profiles efficiently.
    glad it all work out for you...
    Ohio
    6,103
    qball: with your questions (and answers) it doesn't seem like you can add any value here. Please disregard this thread and I'll continue working with members who are knowledgeable in this area.
  15. #15
    447
    why can't you answer the questions?
