Where to start...Help!
Currently Active Users: 2100
Discussions: 200,948, Posts: 2,379,386, Members: 246,309
Old June 21st, 2003, 07:52 PM   Digg it!   #1 (permalink)
williams22's Avatar
Send a message via AIM to williams22
I am interested in learning web programming. I would like to learn things like PHP, MySQL, and XML. What other things should I learn for web programming as well? In what order should I learn these things, I can't seem to find a place to start. Are there any good forums or websites that could help me? Please give me a general idea of how to start learning all of this.
- Chris Nemlich
AIM: bluedevils2223
E-mail: cmn36@cornell.edu
williams22 is offline   Reply With Quote
Old June 21st, 2003, 08:04 PM     #2 (permalink)
I assume you have a working knowledge of simple HTML at first. If not, go to your local library and find a "HTML for Dummies" book. Dont worry, you are not a dummy. After that, it becomes more specialized. It seems you are database oriented, so then look for a database oriented book; start of with PHP (not too difficult) and then move onto more complicated things, such as XML or ASP. Also remember to install the required software on your system to test your skills on.
suchit is offline   Reply With Quote
Old June 21st, 2003, 08:08 PM     #3 (permalink)
williams22's Avatar
Yes, I do know HTML. But my problem is I don't know where to go from here. I am thinking I should learn PHP and MySQL, but I don't realy know what else is out there. Could you list some other things that I may want to learn? Also, could you point towards some good websites or forums that deal with this? Thank you
Old June 21st, 2003, 10:27 PM     #4 (permalink)
Banned
qball's Avatar
Once you get HTML, depends on what you want to do?
XML is really HTML+, Style sheets, HTML+, DHTML is DHML. Think of this helps presentation in browser.
If you want to create dynamic webpages on the server side, regardless of DBs:
PERL is old, but prevalent UNIX.
JSP/Servlets/Beans is java solution. Helps if you are programmer of some level.
ASP is MS solution.
PHP is PHP solution.
All are scripting (except servlets/beans, some PERL) and all can connect to DB.
If you want to create dynamic webpages on the server side with DB. You use the above and connect to a DB, so you need to learn DBs including SQL.
Access, sucks but good starting point.
Oracle, DB2, SQLServer are the big boys.
MySQL is free and somewhat capable.
I would recommend trying PHP with MySQL. Try their websites and www.sitepoint.com should prove useful.
qball is offline   Reply With Quote
Old June 22nd, 2003, 12:57 AM     #5 (permalink)
Learning PHP / MySQL
I found this tutorial helpful when beginning with PHP and MySQL:
http://hotwired.lycos.com/webmonkey/...tutorial4.html
And once you get going, both sites have excellent online documentation with user commentary:
http://www.php.net/docs.php
http://www.mysql.com/documentation/index.html
Good luck.
Cosmo
kozmoh27 is offline   Reply With Quote
Old June 22nd, 2003, 12:58 AM     #6 (permalink)
Telexen's Avatar
Telexen is offline   Reply With Quote
Old June 22nd, 2003, 01:47 PM     #7 (permalink)
tenor_david's Avatar
Here is a good tutorial on XHTML. XML is a general markup language, whereas XHTML is a specific subset of XML.
http://www.w3schools.com/xhtml/
XHTML really separates structure from style. To incorporate stylistic elements, you will need to use some form of Cascading Style Language, whether it be through inline style, embedded style sheets, or calls to external style sheets.
tenor_david is offline   Reply With Quote
Making Health Care Worse (169)
The disrespect of Obama by Russian .. (22)
Is It Just Me? (2934)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Internet Lost (0)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
