Web Content Management Script
Currently Active Users: 1378
Discussions: 200,928, Posts: 2,379,143, Members: 246,295
Old June 28th, 2003, 06:42 PM   Digg it!   #1 (permalink)
RainFire's Avatar
Send a message via ICQ to RainFire
Hello again,
I am looking for a simple to use customizable content management script for converting a couple of sites to.
What is post nuke??
I have checked out the following:
XOOPS http://xoops.org/ - Pretty smooth install, However the coverting of content is its downfall
Xaraya http://www.xaraya.com/ - (looks kool on website but installation and configuation is a pain)
Any suggestions are welcome
Finding new ways to do old things...
Innovation
RainFire is offline   Reply With Quote
Old June 29th, 2003, 01:00 AM     #2 (permalink)
crouse's Avatar
Send a message via ICQ to crouse
you might check out myphpnuke ...... it works pretty good. PHPNUKE and PostNUKE are 2 of the most popular cms available.
USA Linux Users Group
OpenSUSE.us
crouse is offline   Reply With Quote
Old June 29th, 2003, 07:52 AM     #3 (permalink)
RainFire's Avatar
Thanks Crouse...
BTW
I have seen that, what is CMS all about??
I am trying to upgrade my experience in these areas.
Old June 29th, 2003, 12:31 PM     #4 (permalink)
Droppyale's Avatar
Send a message via AIM to Droppyale Send a message via Yahoo to Droppyale
www.hotscripts.com
do a search.... plenty to choose from.
Droppyale is offline   Reply With Quote
Old June 29th, 2003, 02:31 PM     #5 (permalink)
RainFire's Avatar
I am looking for a more specific reccomendation.
Old July 1st, 2003, 12:08 AM     #6 (permalink)
crouse's Avatar
CMS=Content Management System
These can include complete web portals like myphpnuke and postnuke or web forums like IBF, phpbb, or vbulletin. Some are free, some you pay for. I like using the FREE stuff.
The ones I use:
myphpnuke --- my site www.crouse.ws
It's a complete website all in one easy package
phpbb2 -- a nice forum system.
my site www.usalug.org/phpbb2/
I have tried many of these and those are the two I Iike the best so far. There are hundreds of different ones available, but often support is only though online user groups, and picking one with a larger user base usually insures better response to your questions
http://www.myphpnuke.com
http://www.phpbb.com
HTH's
Old July 1st, 2003, 06:30 AM     #7 (permalink)
RainFire's Avatar
Thanks Crouse,
You are the man as usuall...
I like the Myphpnuke...
I have alos found another that is pretty nise as well especially for the themes.
That is mambo - http://www.mamboportal.com/ I have found that the theme visualls rival some pro websites like the ones found at http://www.miles-design.com.
Take a look for me and tell me what you think of it??
Old July 1st, 2003, 08:28 AM     #8 (permalink)
Cruizing
if you want a simple cms system try CMSimple all it needs to run is PHP, you dont need a database it runs everything from 1 page and its very easy to setup.
VERT is offline   Reply With Quote
Is It Just Me? (2867)
Obama the Muslim (14)
Regular Build (2)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
