Help with PHP script
Currently Active Users: 2160
Discussions: 200,946, Posts: 2,379,371, Members: 246,307
Old June 29th, 2003, 04:33 AM   Digg it!   #1 (permalink)
Im just wondering how i would put this script to use?
<?PHP
# This script is Copyright 2003, Infinity Web Design #
# Written by Ryan Brill - ryan@infinitypages.com #
# All Rights Reserved - Do not remove this notice #
## The lines below need to be edited...
###################### Set up the following variables ######################
$to = "you@your.com"; #set addres to send for to
$subject = "Results from your Request Info form"; #set the subject line
$headers = "From: Form Mailer"; #set the from address
$forward = 1; # redirect? 1 : yes || 0 : no
$location = "thankyou.htm"; #set page to redirect to, if 1 is above
##################### No need to edit below this line ######################
## set up the time ##
$date = date ("l, F jS, Y");
$time = date ("h:i A");
## mail the message ##
$msg = "Below is the result of your feedback form. It was submitted on $date at $time.\n\n";
foreach ($_POST as $key => $value) {
$msg .= ucfirst ($key) ." : ". $value . "\n";
mail($to, $subject, $msg, $headers);
if ($forward == 1) {
header ("Location:$location");
else {
echo ("Thank you for submitting our form. We will get back to you as soon as possible.");
Link where i got it from..
Cheers
omc1jz is offline   Reply With Quote
Making Health Care Worse (166)
The disrespect of Obama by Russian .. (18)
Is It Just Me? (2930)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Graphics Card Upgrade Questions (0)
Graphics Card Upgrade Question (2)
Asus P4G8X Mobo (6)
How to convert MP3's (2)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
