July 29th, 2003, 11:48 AM #1Junior Member
- Jul 2003
- 2
help...i've never had this happen
I am using access and I have 2 tables
One table has 28 records and the other has 122 records.
When I do a normal inner join on my 2 fields my query gives me 224 records. What the hell is going on? I do this all the time and never have I had this happen before. Shouldn't it just give me what records are equal?
Please help?
July 29th, 2003, 01:01 PM #2
July 29th, 2003, 01:03 PM #3Junior Member
- Jul 2003
- 2
none of these fields are primary or keyed. There may be duplicate info in both tables.
i don't know why I get 224 records returned.
SELECT PLUG_PORT.KEY, PLUG_PORT.FLOOR, PLUG_PORT.BAY_NODE, PLUG_PORT.SHELF, EQUIPMENT_PORT.PARTITION_FROM, EQUIPMENT_PORT.STATUS_TYPE
FROM PLUG_PORT INNER JOIN EQUIPMENT_PORT ON PLUG_PORT.KEY = EQUIPMENT_PORT.KEY;
July 29th, 2003, 02:08 PM #4
Try this:
SELECT p.KEY, p.FLOOR, p.BAY_NODE, p.SHELF, e.PARTITION_FORM, e.STATUS_TYPE
FROM PLUG_PORT p LEFT JOIN EQUIPMENT_PORT e
ON p.KEY = e.KEY;
What do you intend to use the system for? You have PCI Express on that motherboard. But only a 300 Watt power supply. That will probably need an upgrade for any decent newer graphics card. Also, it...
Does any graphics card work on any...
