Need help with phpbb2
Currently Active Users: 1466
Discussions: 200,927, Posts: 2,379,135, Members: 246,293
Old October 2nd, 2003, 01:37 PM   Digg it!   #1 (permalink)
cracked's Avatar
Send a message via AIM to cracked
hey guys. any of you that are familiar with phpbb2, you will know that when posting a message, when you get done it takes you to a screen with a link back to that thread and a link to the forum you were in and then after an interval of prolly 5 seconds it automatically takes you to the thread.
well what i want to do is shorten that interval to about 1 second but i dont know which file to edit. any ideas?
thanks!
drew
Visit http://duroo.org
cracked is offline   Reply With Quote
Old October 4th, 2003, 12:50 AM     #2 (permalink)
Banned
php.ini:
set:
speed_up_www=1
lolol...
pedantic is offline   Reply With Quote
Old October 6th, 2003, 08:53 PM     #3 (permalink)
cracked's Avatar
um, i dont think that will help bc i cant find php.ini anywhere in the phpbb2 folder. but thanks anyway. anybody else know?
drew
Old October 6th, 2003, 09:30 PM     #4 (permalink)
golfcart's Avatar
In posting.php find '<meta http-equiv="refresh" content="3;url=' and replace the 3 with the number of seconds you want it to wait
golfcart is offline   Reply With Quote
Old October 6th, 2003, 10:11 PM     #5 (permalink)
cracked's Avatar
thanks man, i wish there was a page on the phpbb site that explained which file does what and all that
drew
Old October 7th, 2003, 01:19 AM     #6 (permalink)
Banned
well, if you do find the php.ini, setting:
speed_up_www=1;
won't do much, but worth a try!
I wish life was easy too.
Is It Just Me? (2866)
Obama the Muslim (14)
Fire in DVD (2)
Safe International POS for CC,DC cash.. (0)
Regular Build (0)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
