Results 1 to 3 of 3
    Not Really a Member
    27,879
    SQL - Cleaning up data
    Ok I have a table I'm trying to clean up some pathetic imports.
    We export DHCP tables to a text file every night and then import them into a DB for security tracking.
    Now one of the columns MAC address has something funky in it I can't identify, but it seems to cause wrapping of the text
    I've tried LTRIM RTRIM doesn't remove it
    I've tried REPLACE(columnname, CHAR(13), '') to try to replace carriage returns in the string.. that didn't work either
    HOW can I identify this mysterious white space!?!!
    Its REALLY P'ing me off!! lol
    makes bad data
    Before I was avoiding the problem by just selecting LEFT(mac, 12) .. but when there is no mac address the same problem occurs
    I've also tried CHAR(10) for line feed, and CHAR(9) for tab
    Thoughts?
    T-SQL
    SQL Server 2000
    believe datatype is varchar(20)
    Not Really a Member
    27,879
    HA! I am SQL GOD!
    Ok.. I can wish
    Just dawned on me to try both at the same time
    REPLACE(replace(mac, CHAR(10), ''), CHAR(13), '')
    To get rid of CarriageReturn/LineFeed combos ..
    WOohoo
    Ultimate Member shawshank62's Avatar
    Oct 2002
    southampton, pa
    4,789
    that is a great smilie
    good to see you got your problem solved, btw....
    lmao...smilie
