Setting up a web cam
Currently Active Users: 1175
Discussions: 200,929, Posts: 2,379,148, Members: 246,296
Old December 30th, 2003, 12:19 AM   Digg it!   #1 (permalink)
Urban_Squrill's Avatar
Send a message via MSN to Urban_Squrill
What free host are there that support web cams? And what would i need for one? I have a extra web cam and computer and dsl.
Urban is back.
And yes that is how you spell my name. I am living proof that 2+2=5
dontforget/rgdesb
Urban_Squrill is offline   Reply With Quote
Old December 30th, 2003, 02:19 AM     #2 (permalink)
Old December 30th, 2003, 02:32 AM     #3 (permalink)
HeadBand's Avatar
what do you mean by free host like a website that people can go to and view your webcam on?
Hey who turned sigs on?
Old December 30th, 2003, 02:42 AM     #4 (permalink)
You could probaly hosr it yourself since you already have everything you need.
Rand Dusing is offline   Reply With Quote
Old December 30th, 2003, 11:33 AM     #5 (permalink)
drizzle's Avatar
Send a message via MSN to drizzle
You only need a host that allows you FTP access and software to capture and upload your images (such as Webcam32). I'm sure there are free software alternatives available though.
drizzle is offline   Reply With Quote
Old December 30th, 2003, 04:25 PM     #6 (permalink)
I have tryed that in the past with no sucess. Some one told me that ISS I think its called would do the trick. How do you set up it?
Old December 30th, 2003, 07:01 PM     #7 (permalink)
ISS or IIS? How did you try to host it yourself? Apache is the server software I use and the most used in the world and it's free.
www.apache.org
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
