Need Apache HELP
Currently Active Users: 1736
Discussions: 200,990, Posts: 2,379,884, Members: 246,359
Old December 31st, 2003, 05:58 PM   Digg it!   #1 (permalink)
Urban_Squrill's Avatar
Send a message via MSN to Urban_Squrill
Need Apache HELP
I just downloaded and installed apache Http Server 2.0.48. It seems to only server to my lan. I can see the site only if I use my local ip. How do I make it server to the web?
Urban is back.
And yes that is how you spell my name. I am living proof that 2+2=5
dontforget/rgdesb
Urban_Squrill is offline   Reply With Quote
Old December 31st, 2003, 06:02 PM     #2 (permalink)
rpertusio's Avatar
Send a message via AIM to rpertusio
I bet you need to open a port on your router/firewall.
What router do you have? (and any firewall you have enabled)
- rp
rpertusio is offline   Reply With Quote
Old December 31st, 2003, 06:23 PM     #3 (permalink)
No firewalls. MY router is built in to my modem Westel wirespeed.
Old December 31st, 2003, 06:27 PM     #4 (permalink)
I also have satic NAT enabled for this computer.
Old December 31st, 2003, 06:37 PM     #5 (permalink)
rpertusio's Avatar
I'm not familiar with that particular modem/router. However, you should be able to visit the internal configuration at http://192.168.1.1/
From there, you'll want to look for some kind of Port Forwarding, where you need to direct the right port number to your specific computer (IP address).
Also, another reason that you may not be accessible from the internet, is because port 80 (default for web servers) is possibly blocked. I know many DSL (and cable) companies block certain ports including port 80.
If you find that you ARE being blocked at port 80, then you will need to specify an alternate port in Apache to 'listen' on.
- rp
Old December 31st, 2003, 06:39 PM     #6 (permalink)
I have port forwarding on for a HTTP web server (it is a service config). The firewall is totaly off, and the static NAT directs all un solicited traffic to my computer. I will try to change the port number.
What is a good number?
Old December 31st, 2003, 07:04 PM     #7 (permalink)
rpertusio's Avatar
You could choose a port from 1 to 65535. However, I would stay out of the double/triple digit range,as a lot of other software uses those ports.
I typically choose a random 5-digit port.
Here is a List of known ports. You can choose any port number you'd like... but it is best to find one not used by anything else.
- rp
Old December 31st, 2003, 07:11 PM     #8 (permalink)
Arg I tried at least 20 different ones with the same out come.
Old December 31st, 2003, 07:24 PM     #9 (permalink)
golfcart's Avatar
If it's a default apache install, it is listening on port 80. You will need to forward that one
golfcart is offline   Reply With Quote
Old December 31st, 2003, 07:28 PM     #10 (permalink)
I have it forwarding port 80.
Is It Just Me? (3074)
Health Care Rationing (12)
Delete an OS (17)
Nvidia GTX 260 problem (10)
Internet Lost (5)
Foxconn Blackops x48 MoBo (2)
Q9650 vs. Q9550 (0)
soundmon.exe (8)
Jedi Academy Problem (3)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
Can't open Word (12)
